Do these numbers make sense #1059542
08/22/11 04:42 PM
08/22/11 04:42 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
Just wondering if any one can look at the interval times vs the time slip info and see if everything jives or if the car is falling somewhere.
Please disregard the first pass.
Re: Do these numbers make sense [Re: WILD BILL] #1059543
08/22/11 04:49 PM
08/22/11 04:49 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
1/8 to 1/4 mph seems low to me at 24mph gain...
Mopar Performance
Re: Do these numbers make sense [Re: moparniac] #1059544
08/22/11 05:05 PM
08/22/11 05:05 PM
ill
dennismopar73 Offline
ill
nah! mph gain is what i want to see,, 24 is actually realy great, an ave would be 20 mph.
its the 60 that comes n goes,
tires old, ??
bars correct?
air presure?
maybe a suirter, acce pump??
Re: Do these numbers make sense [Re: moparniac] #1059545
08/22/11 05:07 PM
08/22/11 05:07 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
its been a while since I was running those numbers, but I remember my old Demon ran 10 teens at 132 or so. But it was a small tire deal and best 60 ft was a bout 1.42. I would say your 60 is very nice for the times you are running and the car is working great.
2 kids and a dog
Re: Do these numbers make sense [Re: TonyS451] #1059546
08/22/11 05:18 PM
08/22/11 05:18 PM
ill
ill
youre biggest change is in the 60 , from 1.404- down to a 1.36?
all the rest seams to be closer even when the 60 is off,
even tho the 60 at the best you have is still no faster in the 1/4 that that of the worse ,
Re: Do these numbers make sense [Re: dennismopar73] #1059547
08/22/11 05:20 PM
08/22/11 05:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
tires old, ??
bars correct?
air presure?
I was stating that cause my chally picked up 27mph and my dart picks up 27mph and they were a second apart N/A..
Mopar Performance
Re: Do these numbers make sense [Re: moparniac] #1059548
08/22/11 05:34 PM
08/22/11 05:34 PM
BROOK PARK, OH
BROOK PARK, OH
I guess I was just thinking that given the 1/8 mile times maybe it was losing something after that.
I know I need to do something with the 4 link and perhaps add a rear sway bar to level it out but my focus on TnT nights has been with the girls cars. Sometimes I don;t even get to make a single pass with mine.
Maybe I just need a track rental with someone that knows how to set up a chassis
Re: Do these numbers make sense [Re: WILD BILL] #1059549
08/22/11 05:44 PM
08/22/11 05:44 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
60 Foot 1.40
330 Foot 4.05
660 Foot 6.36
660 MPH 106.91
1000 Foot 8.36
1/4 Mile ET 10.08
1/4 Mile MPH 131.5
These are the idea increments for a 131.5 mph run. Looks pretty close to what you are doing.
Getting old just means you were smarter than some and luckier than others.
Re: Do these numbers make sense [Re: WILD BILL] #1059550
08/22/11 06:18 PM
08/22/11 06:18 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
24mph back half isnt out of the ordinary for a 10.00-10.30 ish car. A car as lite as yours I'd expect maybe 25-26mph, but your not out of the realm of reality at all. 27mph back half is a strong pulling car, or a bigger motor.When you see 27 mph on the back, its typically a 500" or larger motor. I'd say overall its pretty noraml, and not knowing your camshaft, gear and converter, I'd not be too concerned with it. Your incrementals show a failry consistent shift point. The 60' is a significant variance, but not knowing the track conditions, and weather, it may be nothing at all.
RIP Monte Smith
Re: Do these numbers make sense [Re: CompWedgeEngines] #1059551
08/22/11 06:50 PM
08/22/11 06:50 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
For me I am looking at it as a bracket racer .First thing I want to know is the time frames between these runs. be hard to dial the car.with runs like that. I want to know why it pick up and slow down..did the car sit between run 5 and 6.. 10.04 then 10.08 then 10.04 ? looks like something went on out 1/8 -330. 60 ft are the same .? I have to know more info ..like weather ..and what the track was doing. does the car drive around out there ? I thinking rear shocks too stiff ? But I am looking at it to dial it . My car pick up and slow down..but there are reasons why..and I see them and can dial the car for it.
Re: Do these numbers make sense [Re: WILD BILL] #1059552
08/22/11 07:08 PM
08/22/11 07:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill MOST of your issue is the 60'... could be a
multiple of weather, track or both... the 330 tends
to follow the 60'... I would like to see a 25 mph spread
from the front to back half but yours is close... have
you tried jetting.. could be a touch lean
Re: Do these numbers make sense [Re: MR_P_BODY] #1059553
08/22/11 09:56 PM
08/22/11 09:56 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
What I noticed was that your best run was with the worst DA and your worst run was with best DA
Re: Do these numbers make sense [Re: wheelsup68dart] #1059554
08/22/11 10:06 PM
08/22/11 10:06 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I did't see that..that tell us it lean
Re: Do these numbers make sense [Re: VernMotor] #1059555
08/22/11 10:13 PM
08/22/11 10:13 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
bill just asking but did you jet up? runs 5 & 7 pretty close increment but much better air in run 7!
Mopar Performance
Re: Do these numbers make sense [Re: VernMotor] #1059556
08/22/11 10:13 PM
08/22/11 10:13 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
What does Pam and Jenni say... J/K
If you like drag racing, support your local track.
Re: Do these numbers make sense [Re: VernMotor] #1059557
08/22/11 10:27 PM
08/22/11 10:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats what I was getting at
Re: Do these numbers make sense [Re: WILD BILL] #1059558
08/22/11 10:37 PM
08/22/11 10:37 PM
NC
440Jim Offline
440Jim  Offline
NC
To be more helpful, more than just the DA change that day needs to be considered. The temp, humidity, and just to be sure the the barometric pressure for each run. I have seen what happens when the temp goes down and the relative humidity goes up and the ET doesn't change. And the same for morning til afternoon when the temp goes up, but the relative humidity goes down. You saw a 1200 ft DA swing on the same day, that is a lot.
Also if the car did anything different on a run. Spin, moved side to side (driver steer), etc.
Re: Do these numbers make sense [Re: 440Jim] #1059559
08/22/11 10:53 PM
08/22/11 10:53 PM
BROOK PARK, OH
BROOK PARK, OH
Here's the same log book W/ the weather data....
Here's the times each run was made.
run #2 @ 11:36 PM fri night
All the rest on Sat
Run #3 @ 11:26 AM
Run #4 @ 04:02 PM
Run #5 @ 07:27 PM
Run #6 @ 10:01 PM
Run #7@ 11:02 PM
I know have issues to work out in getting the car to leave based on the last post I made and the videos it looks like it's coming up harder on the left and unloading the tires a little just after the install hook.
I have not as of yet had a chance to make any chassis or jetting changes. Paying to much attention to the girls cars I suppose and ignoring my own.
Re: Do these numbers make sense [Re: 440Jim] #1059560
08/22/11 10:54 PM
08/22/11 10:54 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Bill, something that I've not seen mentioned is the reaction times. They're all over the place. Are you sure you're putting the car in the same place each time? That will effect the 60' times quite a bit (not traveling the same distance each time). The split times are acceptable, but like most of us, the run hinges on the 60' times. Just something else to look at.
Brian Dunnigan
Re: Do these numbers make sense [Re: '72CudaRacer] #1059561
08/22/11 11:04 PM
08/22/11 11:04 PM
BROOK PARK, OH
BROOK PARK, OH
The RT's are most likely me being all over the place. I try to just flicker the bottom bulb
