wide band LC-1 #1059461
08/22/11 02:49 PM
08/22/11 02:49 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...tried this on the race forum where i thought sure the guys would be concerned but only got 2 responses.
..who have or do use an Innovate LC-1 or similar a/f monitor to adjust your carb?
..worthwhile?
Re: wide band LC-1 [Re: can.al] #1059462
08/22/11 05:50 PM
08/22/11 05:50 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
do a search for a wideband O2, lots of info on tuning carbs. Tim
Re: wide band LC-1 [Re: can.al] #1059463
08/22/11 06:04 PM
08/22/11 06:04 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Al, I picked one up earlier the year to aid in tuning and it has been helpful. Mount it as close to direct line of sight as you can. I mounted mine under the dash...difficult to watch as I'm going down the road or 1/4 mile. I plan on moving it to the steering column.
As for tuning I've used it to lean out my cruise AFR and Jet my Secondaries for WOT. As for idle I use a vacumn gage since it only reads one bank.
Something that datalogs would make it easier...drive the car , look at the data, adjust, drive again....
It depends on how deep into the tuning you what to get..for just minor jetting issues it;s fine.
Re: wide band LC-1 [Re: Mr340] #1059464
08/22/11 07:12 PM
08/22/11 07:12 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have one and I mounted it on my A-pillar. I think it's an awesome tuning aid!
Re: wide band LC-1 [Re: Mr340] #1059465
08/22/11 07:36 PM
08/22/11 07:36 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..my car was running a little warm,would rattle on E-10 94,so i went 2 stages richer on the cruise thinking it was a bit lean.
seems much better now and i can run w vac advance.
now i'm wondering what my a/f is at idle,cruise and wot... and can i make it better.
Re: wide band LC-1 [Re: can.al] #1059466
08/22/11 07:44 PM
08/22/11 07:44 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
the LC-1 has been helpfull to me.i dont have any down track video.
http://www.youtube.com/watch?v=NIigVBZ8TME
Re: wide band LC-1 [Re: can.al] #1059467
08/22/11 08:41 PM
08/22/11 08:41 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I installed a wideband back in the Spring and now I wish that I would have had it in my budget along time ago. I love mine and I have mine mounted on my dash so that it can be seen as I drive. Mine has helped me find tuning errors that I never could have seen before the installation and they make a great learning tool!!
Re: wide band LC-1 [Re: can.al] #1059468
08/24/11 07:02 PM
08/24/11 07:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i am re-installing my lc-1 now that the car is running again[engine rebuild].how would you mount,where would you get power from.how would you run thw wiring?
