stroker Sb ... jet size holley 850
#1059430
08/22/11 02:18 PM
08/22/11 02:18 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
Say ... what size are you guys running on your stroker sb's . mine is a stroker crate 402 with 850 holley, choke tower cut off and bowl blended . pv's 45's , squirters 37 frt.& rear. 50 cc pumps , jet frt 80 rear jet 82 . big electric pump with 1/2" lines and fuel cell .msd 6al. dart runs 11.0's on motor 60 ft 1.50 . seems to run out of fuel on big end.. 6 pack sealed hood scoop.. maybe more jet for all that fresh forced air ? what do you all think. Thanks !
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!!
11.0's on pump gas .
Re: stroker Sb ... jet size holley 850
[Re: 65_gt_rag_402]
#1059431
08/22/11 03:14 PM
08/22/11 03:14 PM
Posts: 1,365 elmira ny
hp340nos
elmira ny
i run a aed 850 carb on my pump gas 418 stroker in a 3400#,88 dakota p/u,jet size are 79 front 88 rear,35f/37r squirters,pv=4.5.i just ran a 7.37 at 94 in(1/8 mile) over the weekend in the heat,im still tuning on it.i drive this truck to the track 40 minutes one way.mallory 140 pump with -8 line to the regulator,then 2 split -6 to the bowls of the carb.it seems to have plenty of fuel.mike
[Re: hp340nos]
#1059432
08/22/11 08:52 PM
08/22/11 08:52 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
Thanks Mike ! That's rockin ! Appears I'm alittle lean on fuel ... Hope to see a few more opinions . I never did jet up when the scoop was installed. what the theory that you should always keep the jet sizes close in number. to keep an even distribution of fuel in the cylinders. I see you run a big stagger in jet sizes.
[Re: 65_gt_rag_402]
#1059433
08/22/11 09:03 PM
08/22/11 09:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Since you are running a PV you need about 8 jet sizes difference between the PV side to the other ... square jetting is for NON PV applications
[Re: MR_P_BODY]
#1059434
08/22/11 09:31 PM
08/22/11 09:31 PM
Posts: 20,786 A collage of whims
topside
A collage of whims
What do the spark plugs "say"? What's your fuel pressure doing? My 368" SB racecar (Duster) 850DP is 88 square, no PVs, .130 needles/seats, don't recall which shooters or pump cams off the top of my head. Milled choke horn, "6-pack" scoop. Footbrake car, 6000 stall, 904, 5.38s, 13x31 tire, stages @ 1600-2000 and hammered from there. Don't knw if any of that matches your combo. Maybe you don't have enough fuel pump?
[Re: MR_P_BODY]
#1059435
08/23/11 03:22 PM
08/23/11 03:22 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
So mr P ,, you are saying I should be running eg. 80 frt jet and 88 rear jet size with pv's with that being 8 jet sizes apart ? why then are the stock jets like 80 and 81 ? i'm confused . I heard of to jet up 8 sizes if don't use pv's .
[Re: topside]
#1059436
08/23/11 03:31 PM
08/23/11 03:31 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
Fuel pressure is just under 7#'s with a 130gph electric..plugs look ... white and clean porclean , grey soot on first thread . strap color on bend . 34* total timing , 19* initial.msd 6al
[Re: 65_gt_rag_402]
#1059437
08/23/11 03:31 PM
08/23/11 03:31 PM
MR_P_BODY
Are you running a PV both front and back? You can check the Holley web site for the stock jetting if you know the model number
[Re: MR_P_BODY]
#1059438
08/23/11 03:37 PM
08/23/11 03:37 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
mr. p . I think you misunderstood what I said on my pv's . I have pv's in the pri and sec. if that's the case I should still jet up the rear somemore to maybe 84-88. what do you think ?
[Re: MR_P_BODY]
#1059439
08/23/11 03:41 PM
08/23/11 03:41 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
Yes ... pv's #45's in both frt. and rear. i'm running 80 jet frt and 82rear jet now .
[Re: 65_gt_rag_402]
#1059441
08/23/11 06:30 PM
08/23/11 06:30 PM
Posts: 7,506 Az
Crizila
Az
I'm running 79 frt and 89 rr ( front only 4.5 PV )in my 850 / 408 motor. Plugs always color good with mid way ground strap demarcation. You might want to consider dumping the sec side PV and just jetting up. It could make life easier.
Fastest 300
[Re: emarine01]
#1059443
08/24/11 01:57 PM
08/24/11 01:57 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
Yes .... It's has a roll bar in it. chromoly
