MSD box using battery power #1058978
08/21/11 10:29 PM
08/21/11 10:29 PM
Mi.
G-Money1320 Offline OP
Mi.
Does anyone have an idea on why my MSD6al box seems to use more battery than it should? I had sent it out to be tested at their facility and they gave it a clean bill of health. I know its hooked directly to the battery, but my car seems to be running a + charge all the time. Any suggestions on what to change? My alternator and regulator are good. Thanks.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: MSD box using battery power [Re: G-Money1320] #1058979
08/21/11 10:48 PM
08/21/11 10:48 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Based on what?
A needle position on an inaccurate factory gauge?
A needle position on a possibly accurate aftermarket gauge?
Or an actual reading of a volt meter?
Re: MSD box using battery power [Re: G-Money1320] #1058980
08/21/11 10:59 PM
08/21/11 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Greg you need to determine what the actual amp draw
is on that part with all the other stuff off to see
if you really have a problem... make sure everything
is clean
