Re: 426 Hemi Swap 69 Cuda
[Re: MattW]
#1058849
08/21/11 09:15 PM
08/21/11 09:15 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Ed Debevec's (715-267-7141) has complete pre fabbed A-body K-members. Mega Parts might have them to, but not listed on website. Then use the new A-body TTI headers. This is much easier and cheaper to do now that ever. Once TTI stepped up to the plate and made headers, then the K-member guys can make K-members to fit.
[Re: 3ddart]
#1058858
08/22/11 01:53 PM
08/22/11 01:53 PM
Posts: 641 Bergen County NJ
NoJoke
Bergen County NJ
if you go motor plate look in the mopar action magazine archives for the aricles steve maginate did about putting a 440 stage v hemi in his 67 dart. he use a poly bushing on 1 side of the motor plate so the motor could move a little. his is a street car. also i really like the paint on you cuda! dave
Hi Dave thanks its the original air brush paint from 1973 and I had the white redone about 4 yrs ago.. I will look for that artical you said. This car is a street driven car as well...
[Re: BloFish]
#1058860
08/22/11 10:32 PM
08/22/11 10:32 PM
NoJoke
Bergen County NJ
Would love to see this in the projects section so we all can keep up with your project
Yes I will.... The Cuda will be next inline to get done after the 65 Belvedere 1 car is done. So looks like I might just wait till the fall to do this project since im doing chassis work as well to the Cuda... Ill make sure I have plenty of pictures...
[Re: Troy]
#1058863
08/23/11 08:23 PM
08/23/11 08:23 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Once you get the engine in there are a few things that you should do to make things clear. Steering column tube needs to be shortened by a couple inches so it clears the head. I don't remember the exact amount but you can see in the pictures the amount is no more than a few inches. Here is a shot before....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1058864
08/23/11 08:25 PM
08/23/11 08:25 PM
Troy
West Coast, CA
Here is a shot after it was cut down...
[Re: Troy]
#1058865
08/23/11 08:30 PM
08/23/11 08:30 PM
Troy
West Coast, CA
Brake system....You need an offset the master cylinder to make room for the valve cover. I used the bracket that you can get through either Mancini Racing or any Mopar Performance dealer. I made the lines myself saving a few bucks along the way.
