How Do You Do It #1058716
08/21/11 04:40 PM
08/21/11 04:40 PM
MR_P_BODY Offline OP
I'm taking a break at the moment and was thinking how
some of you guys work on your cars with limited equipment...
I was thinking more in the line of welders, mill, lathe
things like that... yeah I'm building a car pretty
much from scratch but got to thinking of others
Re: How Do You Do It [Re: MR_P_BODY] #1058717
08/21/11 04:54 PM
08/21/11 04:54 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Old body man here , I do have welders and air tools but I have always had to think and build outside the box. A level floor and a tape measure goes a long way.
6.50 @105.26
Re: How Do You Do It [Re: MR_P_BODY] #1058718
08/21/11 05:11 PM
08/21/11 05:11 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Barter system. I have friends with Welders, and another friend is a machinest, and can pretty much make anything I can dream up. They help me, I help them with stuff I have and they do not. It's not always car stuff that they need help with. I'm also lucky to have access to having things powdercoated at my work for free.
I'm slowly getting more and more tools for the garage, but it isn't easy on a tight budget. Auctions are a good place to get tools cheap sometimes.
In this picture, the work bench, and vice came from a auction at work, the drill press, and belt sander came from my Grandpa. When my birthday, and Christmas come around I ALWAYS ask for tools, or gift cards for tools.
69 GTX 68 Road Runner
Re: How Do You Do It [Re: Kindafast] #1058719
08/21/11 05:11 PM
08/21/11 05:11 PM
I was a fabricator for 35 years and did bump and paint
before I went into the military and a bunch of other
types of work.... here I think I'm limited with what
I have... I sure would like to pick up a shear and a
nicer break... but I get along with what I have
Re: How Do You Do It [Re: MR_P_BODY] #1058720
08/21/11 05:49 PM
08/21/11 05:49 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
doing chassis work I would square up my lift then mount a laser and work off of it...I have the welders, air tools and a few other goodies but dont have a sheet metal brake or an English wheel nor a planishing hammer, lathe or mill...just dont have the room...perhaps when I move down to Kentucky and have a nice big pole barn, I'll acquire those goodies....
stop the music here...I'm going to be 60 and I'm slowing down like someone thru out an anchor...so its only a hobby..NOT...
thats how I do it...anyways...nice thoughts Mike..
Re: How Do You Do It [Re: smokinwoody] #1058721
08/21/11 06:02 PM
08/21/11 06:02 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I weld about anything with my Lincoln 175. Sure, I'd like to have something bigger with a water cooled torch and adjustable arc. The little wirefeed I have does great for those needs. I have a box break that is only 48", that's its only limit. I would love to have a 52" foot shear. But, it's down on the list cause money is an object. I have a lathe that got broke in the move so the current project's owner brought his little one over for me to use. I have a cheap mill attachement for my big Harbor Freight drill press. It will do the little stuff just fine. But, I have to go to a freinds shop to use his Bridgeport when the big stuff needs to be done. Probably will be hitting him up when I get the new block.LOL
Leon
Re: How Do You Do It [Re: Leon441] #1058722
08/21/11 06:35 PM
08/21/11 06:35 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
one word. creativity.
I'm tackling the restoration of my cuda with a cheap harbor freight flux core wire feed mig, some body hammers, an angle grinder, and a cheap harbor frieght air compressor.
I don't have a shrinker/stretcher. I don't have a sheet metal brake. I don't have a wheel.
so far, I've done ok by taking flat steel, using the work bench, C-clamps, and hammers to do 90 degree bends in flat steel.
then, as I fab patch panels for the outer wheel well under the quarter, with the radius of the wheel opening, AND the lip that lines up with the outer quarter panel...I've found it easiest to bend the lip into the panel, then cut "relief" cuts and bend the piece to match the radius, then weld into place and weld the cuts closed, or add a triangle of metal if the cut is too wide to just weld closed.
it's not the prettiest, and I'm doing a lot more welding than if I could take a flat sheet and just "english wheel" myself a giant patch panel with all the curves and radius' in it.
as I continue on this project, I'll probably try to build my own "sand bag" to pound metal against, and try watching some more you tube videos of guys hand forming steel with just hammers. some of those old school guys are simply amazing at what they can do! I saw a you tube video with a guy using a round wooden hammer, a piece of tree trunk with a cup carved out of it, use that tiny little cup to pound the big flat steel into a bowl...like it was as easy as walking out to the mail box!
**Photobucket sucks**
Re: How Do You Do It [Re: 70Cuda383] #1058723
08/21/11 06:47 PM
08/21/11 06:47 PM
I do have a leather bag for hammer forming... I dont
think I'll ever own a english wheel but have always
wanted one... my shop is FULL already... LOL
Re: How Do You Do It [Re: MR_P_BODY] #1058724
08/21/11 07:26 PM
08/21/11 07:26 PM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
A small mig, some heavy hammers to move metal, small hammers for light work, an 18" section or so of railroad rail, awesome curves and flats, a small vice, a concrete floor, pieces of wood of every size, vice plus wood = sheet metal brake, vise mounted bead roller/shear, and that's about everything for metal work. Tubing bending comes from tie straps, trees of varying sizes, and heat. No joke it works well.
Chris from New Jersey
Re: How Do You Do It [Re: fig426] #1058725
08/21/11 09:55 PM
08/21/11 09:55 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I have a 16" Reed turning lathe, a small mill, mig and arc, (best friend has a tig), a 4 post lift, and a torch. Very little work I can't cobble together somehow. Dave
Re: How Do You Do It [Re: quickd100] #1058726
08/21/11 10:07 PM
08/21/11 10:07 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I am a tool maker by trade. Have a tig and a Bridgeport. Borrow benders and breaks. Thanks to the guys on this site
plus I'm always on craigslist in the tool section
Re: How Do You Do It [Re: MR_P_BODY] #1058727
08/21/11 11:17 PM
08/21/11 11:17 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Surprised I didn't wear out a makita cutting and notching tubing for frame and cage. Did it the hard way.
Yeah, it's got a smallblock.
Re: How Do You Do It [Re: 340B5] #1058728
08/22/11 01:03 AM
08/22/11 01:03 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I have the welders, grinders, lathe, tubing bender, bead roller, and hand tools. Still wanting the lift, mill and sheet metal brake.
Side note to all. Invest in a good alarm!
Some "no good SOB" broke in my shop last Monday morning at 2:37am. Not sure if it was the alarm or me in my jockeys with 45 that scared him/them off. Kind of glad I didn't catch them. I was PO'ed.
Beep
Re: How Do You Do It [Re: Bigbeep] #1058729
08/22/11 04:01 AM
08/22/11 04:01 AM
Oh
His and Her 69's Offline
Oh
I have Great Friends and family that help me out when there is something I need done that I don't have the tools for.
I try and Help them out for a credit or to repay them for their help they have given me when money isn't enough.
My friends talents are being Excellent welders, fabricators, engine machinest, trans builder, electric tech, bodywork, etc.
Without them I wouldn't be able to play and have my stuff look as Good as it does.
I Really Appreciate all that they do for me.
David
Re: How Do You Do It [Re: Bigbeep] #1058730
08/22/11 08:32 AM
08/22/11 08:32 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Beep
Glad you scared them off and they didn't get anything!
my garage is about 150 feet away from the house, and there are no windows on that side of the house. and it's "downhill" from the house. and dark. and at the end of the street where no neighbors can really see the garage.
so yea, it's easy pickings for a thief.
but the house alarm is hooked up to the garage, and the control board for the alarm has it on a 'partition' so that I can have the alarm to the shop on all the time, even if the alarm inside the house is off...like when we're up and walking around at night after dinner, before bed.
Re: How Do You Do It [Re: Bigbeep] #1058731
08/22/11 08:49 AM
08/22/11 08:49 AM
gregsdart Offline
gregsdart  Offline
Beep
Glad to hear it worked out the way it did. I'm like you, a little afraid of what I might do in the wrong circumstances!
45,s put a rather nasty hole in people. Then ya got the cops and lawyers to worry about.
Re: How Do You Do It [Re: Bigbeep] #1058732
08/22/11 09:52 AM
08/22/11 09:52 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Beep
If nothing else, a motion detector light in the garage works. I have 2 alarms, all I have to do is feed'em. They can hear the wife's Nitro from about 700' even before she turns down our street.
Re: How Do You Do It [Re: MR_P_BODY] #1058733
08/22/11 12:50 PM
08/22/11 12:50 PM
Az
Crizila Offline
Crizila  Offline
Az
Before I retired in 02, I ran a large 17 bay general purpose shop. I had access to just about everything except machining equipment. It all went away suddenly when I retired, so I had to pick up the bare essentials ( parts cleaners, mig welder, sand blaster, etc.) in a hurry. There is a lot of good used stuff out there right now. Luckely, I had all my own hand tools and engine building tools, so that wasn't a problem. Built a 30X30 shop and I was back in business. Then we moved. I had to down size to what you see. It's a 24X30 shop with an 11' ceiling ( thinking about installing a lift in the future ?.) I can do just about anything I need to do except engine machining work. Also gave up all my valve grinding equipment.
Fastest 300
Re: How Do You Do It [Re: Crizila] #1058734
08/22/11 02:14 PM
08/22/11 02:14 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
As far as milling goes, a friend i work with used a cross-slide vise in a drill press for light milling.
A couple months ago I ported through an iron head and had to weld it. The machine shop tried to spot-face where the head bolt goes and sent it back saying it was too hard and didn't want to risk tooling, so I bought a grinding stone, dressed it and did it myself in my drill press.
