Re: Lokar Dip stick accuracy?
[Re: rickraw]
#1058698
08/21/11 04:43 PM
08/21/11 04:43 PM
Posts: 3,456 Out West
408strokerdart
Out West
just ziptie ur stick to the tube. make sure the handle is even with the top of the tube. mark the stick at bottom of the hole on the case. that will be the hot run mark. check oil level in park or neutral, either one will work. stay safe, seeya.
So you are saying that the bottom of the hole in the case is the hot running level?
[Re: 408strokerdart]
#1058699
08/21/11 04:51 PM
08/21/11 04:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I thought that was true with a 727(top of the case) but I cant say about a glide... I also thought you could check a glide in park....
[Re: MR_P_BODY]
#1058700
08/21/11 08:29 PM
08/21/11 08:29 PM
408strokerdart
Out West
Yeah Mike, I was told by a reputable 'glide builder that the correct level while running (in both neutral and park) is the bottom of the dipstick hole.
