My rear end howls #1058303
08/21/11 09:40 AM
08/21/11 09:40 AM
Mid Michigan
Coronet-R/T-Rag Offline OP
Mid Michigan
I've got a 8 3/4 in my B Body that howls and whines. Here are the symptoms:
1. It's constant but much worse after it gets warm.
2. It's worse between 50 - 70 mph. Hardly notice below 40 mph.
3. It doesn't change under accel or decell.
4. The rear has a aftermarket 3.55 ring and pinion set up by a pro.
5. The axles have original bearings and have about 100k on them.
What do you think???
Re: My rear end howls [Re: Coronet-R/T-Rag] #1058304
08/21/11 09:59 AM
08/21/11 09:59 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Have you checked the end play on the adjuster side? Mine does it every few years and I tighten the bearing play and it goes away. Of course I need to do new bearings all the way around with seals but Ive been to lazy.
Mine was more of a low groan.
Re: My rear end howls [Re: Coronet-R/T-Rag] #1058305
08/21/11 11:36 AM
08/21/11 11:36 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Describe the noise.
Gear howl is usually a high-pitched "eeeee" sound, that comes and goes with RPM on float. It rarely occurs on drive and coast simultaneously, unless the backlash is set too tight.
A bad wheel bearing will rumble at all speeds.
A bad U-joint will squeak, growl or vibrate.
Re: My rear end howls [Re: DoctorDiff] #1058306
09/12/14 10:32 PM
09/12/14 10:32 PM
Mid Michigan
Mid Michigan
I posted this a while ago but have not been able to get this rear end to stop howling. The noise is a constant "EEEEEEEEE". I didn't add any sure grip additive, but that's never helped me with noise in the past. Should I chalk this up to an aftermarket gear?
Re: My rear end howls [Re: Coronet-R/T-Rag] #1058307
09/13/14 01:10 PM
09/13/14 01:10 PM
4. The rear has a aftermarket 3.55 ring and pinion set up by a pro. What do you think???
Not sure if this is relevant or not but it crossed my mind: did it start acting up from day 1 (after being setup) or later on down the line?
Re: My rear end howls [Re: RapidRobert] #1058308
09/13/14 02:13 PM
09/13/14 02:13 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i hear once they make noise due to incorrect setup they will always be noisy is that true?
Re: My rear end howls [Re: ademon] #1058309
09/13/14 02:19 PM
09/13/14 02:19 PM
Maryland
gofastboater Offline
Maryland
YES !!!!!!
