Electric air fuel ratio gauge?? #1058290
08/21/11 05:09 AM
08/21/11 05:09 AM
Idaho, USA
W
White440 Offline OP
White440  Offline OP
W
Idaho, USA
Electric air fuel ratio gauge-
Ok I have seen these around and was wondering if anyone had ever used one??
I was thinking of putting one in my truck and trying it out only because I have the sensor sitting there from doing my TBI to carb swap and thought what the heck but I was wondering if anyone had on this?
"Full throttle until you see GOD then brake!" <img src="/ubbthreads/images/graemlins/drive.gif" alt="" /> Life's to short to ride the brakes!
Re: Electric air fuel ratio gauge?? [Re: White440] #1058291
08/21/11 09:06 AM
08/21/11 09:06 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
2 types.
ok. 3 really...
1 "narrow band" cheap. nothing more than a moving gauge and a light show. only reads a very narrow range near stoich... around 14.7. it might go one full up and down, i.e. 13.7-15.7
2 wide band. expensive. this reads AFRs from ambient air at 20.8% to full rich, I've had mine reading at 10.0:1 before when I started tuning my Dakota.
3 wide band with data logging capability. for tuning, THIS is what you want. watching your AFRs on a gauge while accelerating at WOT is NOT an easy feat to do. it's much easier to use a gauge that data logs, and allows you to "play back" the run on a computer, with a graph and chart, showing you the AFRs through the RPM range, so you know where you're lean, rich, or spot on.
**Photobucket sucks**
Re: Electric air fuel ratio gauge?? [Re: 70Cuda383] #1058292
08/21/11 04:15 PM
08/21/11 04:15 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have the AutoMeter Wideband...it has data logging but I have nothing to hook it up to. Maybe there is an adapter. Anyways, you need the wideband. Mine reads AFR in Hg and also Lambda. I stick with the Hg. It has been a life saver. Dialing in a single carb is one thing, I have two edelbrocks in line. I have it tuned exactly where I want it to be.
As a plus, you can rent it out for $25/day to your friends and make some of the money back
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Electric air fuel ratio gauge?? [Re: Pyper70] #1058293
08/21/11 04:58 PM
08/21/11 04:58 PM
Idaho, USA
W
White440 Offline OP
White440  Offline OP
W
Idaho, USA
Thanks guys.
I was in the parts house looking for a new vac gauge and stumbled across one of there cheepo's and it got my mind thinking. I know I don't want one of theres but didn't know witch way to go.
Thanks for the help guy's.
