Good Day, then..... BANG, clunk clunk ****UPDATE***
#1058264
08/21/11 01:57 AM
08/21/11 01:57 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Scratch one 8-3/4. Pretty strange really, I raced all day with no issues (6 passes), then on the way home (My car is a Street / Strip - drive it there and drive it home ride) I'm pulling away from a stop-light under normal accelleration and as I shift into 2nd: BANG (followed by lots of ugly noise). Ended up covering the last 6 miles home as shown below I'm not too bummed, though. I just bought a new set of gears and was in the process of setting up a new rear-end because this one has been singing a howling song for some time. It feels like I broke a pinion, I'll know more later in the week when I have a chance to pull the chunk. I just hope it didn't take my SG unit with it, or damage my axles, as I need those. More to come on this.
Re: Good Day, then..... BANG, clunk clunk
[Re: StealthWedge67]
#1058265
08/21/11 02:08 AM
08/21/11 02:08 AM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
Sorry to hear that...great looking car... Curtis
Taking over the World one win light at a time.
#1058266
08/21/11 05:06 AM
08/21/11 05:06 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
The ring gear is usually the first to go. I broke a ring gear in my 10 second Duster one night, I could hear the chunka, chunka noise on the return road but it still made 4 more passes for the win and the track championship that night. lol.
You should be OK but if that's an automatic you really should take it apart and check the over running clutch. It will only take a paper and seal kit to check and they are cheap.
[Re: Guitar Jones]
#1058267
08/21/11 08:39 AM
08/21/11 08:39 AM
Posts: 16,928 NC
440Jim
NC
Sorry to hear of the breakage. I agree with checking the transmission sprag. It might be a 50/50 chance IMO.
#1058268
08/21/11 09:15 AM
08/21/11 09:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Were you into 2nd... most times it doesnt hurt the axles or the other stuff in there
[Re: 383man]
#1058271
08/25/11 01:20 AM
08/25/11 01:20 AM
StealthWedge67
Puyallup, WA
Well, Autopsy revealed one spider gear sheered clean and another with about half the teeth broken off. Looks like the pieces then got out into the ring gear path, as two teeth are partially broken on it.
Looks like its time to call Dr. Diff.
Oh, and the car ran pretty good, Ron. Although it slowed a bit in the heat of the afternoon. No suprise, since I know I'm running a little on the rich side.
#1058272
08/25/11 02:15 AM
08/25/11 02:15 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I agree with the other posters, if it's an Automatic inspect the sprag....
[Re: 1_WILD_RT]
#1058273
08/25/11 02:46 AM
08/25/11 02:46 AM
StealthWedge67
Puyallup, WA
okay guys.... Is there any way to verify the overrunning clutch (sprag) without Removing the tranny? I'd really rather not R&R the tranny. This happened at pretty low RPM, at partial throttle, with very little pressure on the trans or rear. Is there any typical conditions that would normally take the sprag out?
