dome light troubles #1058057
08/20/11 08:55 PM
08/20/11 08:55 PM
Frankenmuth, Michigan
Beazly464 Offline OP
I have a 68 satellite and my dome light won't turn off and I'm not sure what could be the problem right now I just pulled the fuse so my battery doesn't die.
Re: dome light troubles [Re: Beazly464] #1058058
08/20/11 09:18 PM
08/20/11 09:18 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
door jamb switch, dome light switch or a short (which would blow the fuse).
Re: dome light troubles [Re: Beazly464] #1058059
08/21/11 12:19 AM
08/21/11 12:19 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
lets go to the easier first... and assuming you oviouslly have the correct 1004 bulb being this should be a new problem using the same bulb you had ever.
have you checked the dimmer thumbwheel position ? it looks kinda stupid, but... who knows
