Wide tire + Axle off center = tire rub #1057961
08/20/11 03:12 PM
08/20/11 03:12 PM
challconv70 Offline OP
I am running 10" wide wheels with 255/50/17's on a challenger and have minimal clearance on the drivers side and 1/2 inch clearance on the passenger side. I have brought in the wheel lip a little, but prefer not to go more. Are there any options for shifting the axle slightly or do I just need to go with a smaller tire or different back spacing?
Re: Wide tire + Axle off center = tire rub [Re: challconv70] #1057962
08/20/11 03:54 PM
08/20/11 03:54 PM
eyeball the 4 corner shackle to body mounts & see if there's room to move/slot em slightly
Re: Wide tire + Axle off center = tire rub [Re: challconv70] #1057963
08/20/11 05:38 PM
08/20/11 05:38 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
I had to put a 1/4 inch spacer between the wheel and brake drum on the passenger side of my 72 Challenger to keep the tire from rubbing the spring. Maybe it's a factory offset but 1/2 " what would that help ??????????????????????
Re: Wide tire + Axle off center = tire rub [Re: challconv70] #1057964
08/20/11 06:27 PM
08/20/11 06:27 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Installing a 68-70 B body rear axle will give you the room you need, they are narrorow, and it is a bolt in swap.
Re: Wide tire + Axle off center = tire rub [Re: sthemi] #1057965
08/21/11 09:02 AM
08/21/11 09:02 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
It's only a bolt in if you buy the 1" offset spring brackets and shackels.
Re: Wide tire + Axle off center = tire rub [Re: challconv70] #1057966
08/21/11 10:45 PM
08/21/11 10:45 PM
Canada
CrAzYMoPaRGuY Offline
Canada
My Charger had the rear offset to one side about 3/8" when I got it.
The front spring hangers were both installed to slightly offset one way, I flipped one of the hangers and now the diff is centered. Might be worth looking at?
CrAzYMoPaRGuY
Re: Wide tire + Axle off center = tire rub [Re: CrAzYMoPaRGuY] #1057967
08/21/11 11:38 PM
08/21/11 11:38 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Not sure what you mean by "brought the lip in"...Anyhow if all else fails you could cut the perches off and center the rear...And correct any geometry problems in the process...
