Holley electric fuel pump - Red or Blue? #105751
08/16/08 09:04 AM
08/16/08 09:04 AM
michigan
440whiteboy Offline OP
michigan
I need to change my electric fuel pump.
want to go with a Holley Im told -
the Holley red is 7 -
the blue is 9 rated to 14 with an regulator.
I'm running on the street a 440 -
750 holley dual feed single pump with 4.5 power valve, 516 closed chamber heads, 509 cam, headers, 2 1/2" 'H' pipes -
which is the better pump to use?
They only see Stars...
when hit by a Mopar!
Re: Holley electric fuel pump - Red or Blue? [Re: 440whiteboy] #105752
08/16/08 09:12 AM
08/16/08 09:12 AM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
I'm running a Holly Black on a 406 with a 750 holly. I've had it for 3 years on this engine and was run on a 440 for at least 5 years before I got it. You may want to look at the Black pumps, very reliable.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Holley electric fuel pump - Red or Blue? [Re: StandOnIt] #105753
08/16/08 09:21 AM
08/16/08 09:21 AM
michigan
michigan
I just checked out Holley's site - the black looks like the same output is the blue except it will accept methane/alcohol -
I dont plan on using that -
so I'll go with the blue ---
thanks -
Re: Holley electric fuel pump - Red or Blue? [Re: 440whiteboy] #105754
08/16/08 12:27 PM
08/16/08 12:27 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Do you like noisy pumps?? If not get a mallory.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Holley electric fuel pump - Red or Blue? [Re: CJK440] #105755
08/16/08 01:52 PM
08/16/08 01:52 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
The black pump is a pump you can grow with.
Better yet spring for the self regulated Holley pump with the two outlets.
Holley Performance
The blue does not flow the same as the black as the numbers show on this chart.
Re: Holley electric fuel pump - Red or Blue? [Re: 440whiteboy] #105756
08/16/08 04:31 PM
08/16/08 04:31 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Out of four or five red pumps I've had(4 or 5 diff cars) only one of them failed out of the box, due to excessive cosmoline or other crud on regulator plunger. Cleaned it out and never had another problem. As said, you will hear the thing run. I had a newer comp 110 mallory that wimped out a little in the IRP heat and ruined a good light I had cut and cost me a money round.
Re: Holley electric fuel pump - Red or Blue? [Re: buildanother] #105757
08/16/08 05:36 PM
08/16/08 05:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son and I both run the Holley red pumps on our mid 11 cars. His has been on the car since 1997 with no problems ever. I run an 850 DP and it feeds my car with no problems. I like it to make a little noise as that way I know its working. Ron
Re: Holley electric fuel pump - Red or Blue? [Re: 440whiteboy] #105758
08/17/08 01:27 PM
08/17/08 01:27 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
the red is rated lower and does not need a regulator ,its only flowing about 4psi uner load, the blue about 7 under load. if you plan to just use the car for street use then the red is fine unless you might see some strip use id recomend the the blue with the rgulator set at 6.5. i ran a goofree flowing filter also. the mallory comp. 110/140 are also good and affordable iused them on a blown nova sb and had no fuel problems. good luck bob
Re: Holley electric fuel pump - Red or Blue? [Re: moparsquid] #105759
08/17/08 01:33 PM
08/17/08 01:33 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My blue has been running about 3 years...and is annoyingly loud.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Holley electric fuel pump - Red or Blue? [Re: GoodysGotaCuda] #105760
08/17/08 06:07 PM
08/17/08 06:07 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
My blue is audible when I turn on the ignition but when the 390 fires off I can't hear it at all..... I do have a return line so maybe that may be a reason why mine is not so loud........ TBF
Re: Holley electric fuel pump - Red or Blue? [Re: tpabayflyer] #105761
08/19/08 09:01 AM
08/19/08 09:01 AM
michigan
michigan
thanks guys for your input with this -
I ended up with the blue using the counter person's advice that he uses it.
It was early saturday morning after I had read the first reply that I went out to buy this, I wanted to get up & running to get back on woodward for the cruise.
Now that I have it installed, like some of the others said I too like to hear it running.
I also had debri in my last filter before the carb - I replaced that and flushed cleaned all lines after I noticed I had one older line I changed it out, so now all is new - tank, pump, lines & two screen filters. I still had her act up again that evening with the same thing happening?
I have noticed that in my carb that in the primary the spray is under the venturi tube only on one side - so now I think I need to redo the carb in hope to clean it out???
A couple Questions -
1) Do I need to run an return line?
2) Should I install the safety switch?
3) I have a 20a fuse with a toggle switch,
should I have a relay instead?
.......if so - how would I do the install's?
Re: Holley electric fuel pump - Red or Blue? [Re: 440whiteboy] #105762
08/19/08 11:02 AM
08/19/08 11:02 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
1) No, you don't have to.
2)Safty switch is ALWAYS a good idea with a elec. pump.
3)20A fuse is more than needed with a holley, if I remember they pull less than 10a. Relay would depend on where you are now pulling power from now. Can that cir. handle the extra load? Also if you are going to run a relay it is still a good idea to fuse it.
Re: Holley electric fuel pump - Red or Blue? [Re: rrunner] #105763
08/20/08 09:15 AM
08/20/08 09:15 AM
michigan
michigan
thanks rrunner good advice -
will check into the safety switch,
holley says to use a oil pressure type.
my circuit is direct to the fuse block by itself -
the data sheet says its 7a, another post said to use the 20a is why I had it in, will change out to a 10a -
