Hemi tube seal question??????????????????????? #1057554
08/19/11 08:40 PM
08/19/11 08:40 PM
Great Neck,LI,new york
hemi-itis Offline OP
Is there anything different about these rubber seals that go inside the inserts??Doing some final tidbits and want new rubbers.Will any work from a regular )-ring set?
http://chucker54.stores.yahoo.net/mihehetuseki.html
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi tube seal question??????????????????????? [Re: hemi-itis] #1057555
08/19/11 08:49 PM
08/19/11 08:49 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i got mine form the hardware store
Re: Hemi tube seal question??????????????????????? [Re: rickraw] #1057556
08/19/11 08:59 PM
08/19/11 08:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i use to love mancini but they have dropped the ball on me several times in the past 6 months. like really bad, and i am much more calm and understanding than i use to be
Re: Hemi tube seal question??????????????????????? [Re: hemi-itis] #1057557
08/20/11 01:57 AM
08/20/11 01:57 AM
Take on eof the old undamged ones to a hydraulic hose shop and have them match them up with good O rings
Re: Hemi tube seal question??????????????????????? [Re: Cab_Burge] #1057558
08/20/11 03:49 AM
08/20/11 03:49 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The hydraulic shop will give you the options of Nitrile, butyl, viton, n-butyl, etc. Pick your material by the temperature and resistance to oils. I paid $.86 each and it was 10.00 to drive down to get them sized. Tim
Re: Hemi tube seal question??????????????????????? [Re: astjp2] #1057559
08/20/11 07:08 AM
08/20/11 07:08 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
There's another option, take one of your old ones and cut it with a razor blade. Pickup some oilring material the same diameter. Cut to length and use super glue on the ends. It works. Dave
Re: Hemi tube seal question??????????????????????? [Re: quickd100] #1057560
08/20/11 07:26 AM
08/20/11 07:26 AM
NJ
SSDAcuda Offline
SSDAcuda  Offline
NJ
http://www.mcmaster.com/#o-rings/=dp6lw8 for all your o-ring needs if you cant find them locally.
SS/DA 1924
Re: Hemi tube seal question??????????????????????? [Re: SSDAcuda] #1057561
08/20/11 09:46 AM
08/20/11 09:46 AM
I did hit an o-ring kit in one of the shops I tow for.I only had the insert with me and took some that fit well.When I got back to the garage to try then,the spark plug tube would not fit inti the insert Back to the o-ring kit
Re: Hemi tube seal question??????????????????????? [Re: hemi-itis] #1057562
08/20/11 09:16 PM
08/20/11 09:16 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
when put new rings in the keith black duel plug mag covers they actually are real thin and go inside the tube hole wall
when tried to put tube in was no way it was happing
took some oil and rubed the tubes good ,made a lap around the o ring
gave the tube a twisting push and glided right in
maybe it can help
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
