Brazing an exhaust port on an iron head
#1056744
08/19/11 01:09 PM
08/19/11 01:09 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
I know that its always said that you can braze intake ports to fix cracks, pinholes, etc because of the lower temps found in the intake port....
...but when you are taking about exhaust ports you CANT braze them due to the increased temperatures found there which would soften the bronze and it would do little to prevent cracks or pin holes from seeping water.
Now....
What if you had an exhaust port that had been opened up a tad bit too much and you would want to fill it up some by brazing and then reworking it. This is at the very end of the port opening where the gasket sits. Seems somebody port matched and went a bit overboard and enlarged the port opening a bit too much.
This port doesnt have cracks or pin holes, I just want to fill it up some at the very end of it and port match it again.
Will bronze hold up or will it melt????
Any other ideas?
Thanks!
Domingo
Re: Brazing an exhaust port on an iron head
[Re: S/ST 3040]
#1056746
08/19/11 01:27 PM
08/19/11 01:27 PM
domingo
EL Master
EL Master
Lima, Peru
Brazing is a very common practice for repairing exhaust ports.
really?? I always thought it was OK on the intakes but a real NO NO on the exhausts!!!!
Is there a possibility that a bronze filling actually MELT off on an exhaust port?
[Re: domingo]
#1056749
08/19/11 02:34 PM
08/19/11 02:34 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I have seen exhaust ports brazed and filled on the bottom when raising them for SS etc. The intake side could be epoxied, but exhaust is brazed.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1056752
08/19/11 05:17 PM
08/19/11 05:17 PM
domingo
EL Master
EL Master
Lima, Peru
Thats exactly whay I am looking to do....kinda what SS racers do. I know they raise the exh ports on the heads and make em smaller....I wonder if they do that by brazing the exh ports. If that is the case, I know I will be 100% safe.
It'd be great if Jeff (modern cyl head) could chime in....I know he does heads for the SS guys.
[Re: MR_P_BODY]
#1056757
08/21/11 09:25 AM
08/21/11 09:25 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
If your really worried about brasing it, weld it with high content nickle rod
+1 on that. I had a pin hole in an iron head. we heated it with a torch and zapped it with a high nickle rod. I think the heads are still around to this day.
[Re: torkrules]
#1056758
08/21/11 11:45 AM
08/21/11 11:45 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I don't know a lot about brazing yet, but I've watched my dad do it a few times, oxy/acetylene hot blue flame to heat the metal to cherry red and touching the rod to it to melt the brass into it...that's GOTTA be hotter than any exhaust is going to get. unless you run stupid lean! but, if you're really worried, maybe look for someone who can weld cast aluminum up with steel rod.
**Photobucket sucks**
[Re: 70Cuda383]
#1056759
08/21/11 12:09 PM
08/21/11 12:09 PM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
I'd pay to see that trick
[Re: justinp61]
#1056760
08/21/11 12:17 PM
08/21/11 12:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
LOL.... same here
[Re: domingo]
#1056761
08/21/11 12:30 PM
08/21/11 12:30 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Back in the 70's, I was given a 70 Pinto with a 1.6 crossflow head that was wounded. After taking it apart, it had a burnt ex valve and cracked seat. After consulting with the wise shop owner that I worked for, I gound out the crack, we heated the head in the oven to 400F then brazed/filled the crack. Then, I had a seat put in it and ported the crap out of it. That motor got me though college and saw 7500rpm daily.
8.30's @3400 lbs
