Brazing an exhaust port on an iron head #1056744
08/19/11 01:09 PM
08/19/11 01:09 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I know that its always said that you can braze intake ports to fix cracks, pinholes, etc because of the lower temps found in the intake port....
...but when you are taking about exhaust ports you CANT braze them due to the increased temperatures found there which would soften the bronze and it would do little to prevent cracks or pin holes from seeping water.
Now....
What if you had an exhaust port that had been opened up a tad bit too much and you would want to fill it up some by brazing and then reworking it. This is at the very end of the port opening where the gasket sits. Seems somebody port matched and went a bit overboard and enlarged the port opening a bit too much.
This port doesnt have cracks or pin holes, I just want to fill it up some at the very end of it and port match it again.
Will bronze hold up or will it melt????
Any other ideas?
Thanks!
Domingo
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056745
08/19/11 01:17 PM
08/19/11 01:17 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Brazing is a very common practice for repairing exhaust ports.
Re: Brazing an exhaust port on an iron head [Re: S/ST 3040] #1056746
08/19/11 01:27 PM
08/19/11 01:27 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
really?? I always thought it was OK on the intakes but a real NO NO on the exhausts!!!!
Is there a possibility that a bronze filling actually MELT off on an exhaust port?
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056747
08/19/11 01:28 PM
08/19/11 01:28 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I've seen exhaust manifolds that were brazed to fix a broken ear, or crack last years and years...
Re: Brazing an exhaust port on an iron head [Re: DJVCuda] #1056748
08/19/11 02:16 PM
08/19/11 02:16 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Well, exhaust manifolds are farther away from the heat....and an ear is not in direct contact with the heat.
I am concerned about how will a bronze filling behave INSIDE the exh port walls!
Once again, it wont be sealing any cracks or pinholes or trying to prevent water from seeping. The exhaust port is just fine, and it passed the water pressure test just fine. I just want to fill it some to rework it.
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056749
08/19/11 02:34 PM
08/19/11 02:34 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I have seen exhaust ports brazed and filled on the bottom when raising them for SS etc.
The intake side could be epoxied, but exhaust is brazed.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056750
08/19/11 03:54 PM
08/19/11 03:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your really worried about brasing it, weld it
with high content nickle rod
Re: Brazing an exhaust port on an iron head [Re: MR_P_BODY] #1056751
08/19/11 04:46 PM
08/19/11 04:46 PM
dogdays Offline
dogdays  Offline
The wall of the exhaust port has water on the other side so it probably is cooler than the exhaust header.
R.
You could drill a hole in an exhaust header or manifold and insert a brazing rod with a square tip. Run the engine up some hills and then take out the rod and see how it looks. This actually sounds like a fun experiment.
Re: Brazing an exhaust port on an iron head [Re: Hemi Allstate] #1056752
08/19/11 05:17 PM
08/19/11 05:17 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thats exactly whay I am looking to do....kinda what SS racers do. I know they raise the exh ports on the heads and make em smaller....I wonder if they do that by brazing the exh ports. If that is the case, I know I will be 100% safe.
It'd be great if Jeff (modern cyl head) could chime in....I know he does heads for the SS guys.
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056753
08/19/11 05:40 PM
08/19/11 05:40 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I cant see the port reaching any critical melt temperature given the fact that the head is constantly being cooled by water. It might cool slower than aluminum, but I cant see the head itself reaching any temperature where the repair would melt.
If an exhaust manifold that is not cooled holds, the head will hold fine is my thought on it.
No????
Re: Brazing an exhaust port on an iron head [Re: POS Dakota] #1056754
08/19/11 06:06 PM
08/19/11 06:06 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The melting point of brass is 1700 degrees, aluminum is 1200 degrees.
Getting old just means you were smarter than some and luckier than others.
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056755
08/20/11 11:45 AM
08/20/11 11:45 AM
Mt. Eden Ky.
Mt. Eden Ky.
How's this look? It may be some of Jeff's work!
1996 Ram 1500 Sport
1968 road runner
Re: Brazing an exhaust port on an iron head [Re: Hemi Allstate] #1056756
08/20/11 12:11 PM
08/20/11 12:11 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thats all I needed to see!!! Thanks! I will go ahead and fix my heads that way....thanks!!!!
Re: Brazing an exhaust port on an iron head [Re: MR_P_BODY] #1056757
08/21/11 09:25 AM
08/21/11 09:25 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
+1 on that. I had a pin hole in an iron head. we heated it with a torch and zapped it with a high nickle rod. I think the heads are still around to this day.
Re: Brazing an exhaust port on an iron head [Re: torkrules] #1056758
08/21/11 11:45 AM
08/21/11 11:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't know a lot about brazing yet, but I've watched my dad do it a few times, oxy/acetylene hot blue flame to heat the metal to cherry red and touching the rod to it to melt the brass into it...that's GOTTA be hotter than any exhaust is going to get.
unless you run stupid lean!
but, if you're really worried, maybe look for someone who can weld cast aluminum up with steel rod.
**Photobucket sucks**
Re: Brazing an exhaust port on an iron head [Re: 70Cuda383] #1056759
08/21/11 12:09 PM
08/21/11 12:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd pay to see that trick
Re: Brazing an exhaust port on an iron head [Re: justinp61] #1056760
08/21/11 12:17 PM
08/21/11 12:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL.... same here
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056761
08/21/11 12:30 PM
08/21/11 12:30 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Back in the 70's, I was given a 70 Pinto with a 1.6 crossflow head that was wounded. After taking it apart, it had a burnt ex valve and cracked seat. After consulting with the wise shop owner that I worked for, I gound out the crack, we heated the head in the oven to 400F then brazed/filled the crack. Then, I had a seat put in it and ported the crap out of it. That motor got me though college and saw 7500rpm daily.
8.30's @3400 lbs
Re: Brazing an exhaust port on an iron head [Re: domingo] #1056762
08/21/11 12:52 PM
08/21/11 12:52 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
you had better know how much pre heating and cool down time it needs. all I have seen done used a furnace to braze
home of the
Sox and Martin Hemi Duster
