electric fuel pump on tunnel ram 340 ??? #1056742
08/19/11 01:09 PM
08/19/11 01:09 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
So what would be a good fuel pump to use?
12.5 340 heavily ported X heads mopar 509 hydraulic cam 273 rockers 4.56 gears 4 speed 1 3/4 headers with a weiand tunnel ram with two 600 holleys. It is in a 73 duster.
Also while we are at it how should I set up the linkage for the carbs? Open both of the primaries evenly (easy to fabricate) or get some sort of progressive linkage?
Re: electric fuel pump on tunnel ram 340 ??? [Re: HotRodDave] #1056743
08/19/11 01:24 PM
08/19/11 01:24 PM
It's always cheaper and better to buy a good pump to start with instead of replacing it later if you hop the motor up more, IE stroker I would hook the linkage up one to one, direct in other words
