Page 7 of 8 1 2 3 4 5 6 7 8
Re: Some B1 Original pics......... [Re: Bob_Coomer] #105645
12/08/11 10:14 PM
12/08/11 10:14 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
if i had a set of those brian B1 heads they would go in the bed with me at night right between me and the ol' lady! lol
74 dart sport 440 www.Csucarbs.com
Re: Some B1 Original pics......... [Re: shoebox] #105646
12/08/11 10:53 PM
12/08/11 10:53 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
You'd rather mount your heads on the engine
A guy emailed me from Mo. last night. He bought a car off me lat year. He said he had a set of B1 originals ready to bolt on for 2100 bucks
Re: Some B1 Original pics......... [Re: Bob_Coomer] #105647
12/08/11 11:11 PM
12/08/11 11:11 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
X3...does that car run like it has 900hp?
Can we see the dyno on that?. That is a lot for a set of BS heads.
RIP Monte Smith
Re: Some B1 Original pics......... [Re: Al_Alguire] #105648
12/09/11 01:14 AM
12/09/11 01:14 AM
ky
68roadrunner Offline
ky
As I have said in the past if you cannot make 800hp with a decent set of B1's your doing it wrong. My 67 Valaint was a basic 511 low deck with a good set of B1's that went 9.0's at 150 weiging 3470lbs. My current MC motor seems to run ok
i would say you are right there, my 499 -1 setup figures out to about 750hp 5.0x at 1854lbs
Re: Some B1 Original pics......... [Re: 68roadrunner] #105649
12/09/11 01:18 AM
12/09/11 01:18 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I believe Im going to call Scott at Koffel's next week and do the rocker upgrade, unless someone has a deal to sell me.
Re: Some B1 Original pics......... [Re: Mopar-Al] #105650
12/09/11 01:29 AM
12/09/11 01:29 AM
ky
ky
is the bi rockers the same as the indy -1's? just wondering.
Re: Some B1 Original pics......... [Re: 68roadrunner] #105651
12/09/11 02:15 AM
12/09/11 02:15 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
No they are different.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Some B1 Original pics......... [Re: pittsburghracer] #105652
12/09/11 01:01 PM
12/09/11 01:01 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
You stuff flies Al, I would agree the B-1 stuff is stought. Heck my 498" B1-BS makes just under 900HP.
Best Machine and Muscle Motors have done PSO deals and that stuff is real good.
For the money B-1's are hard to beat.
How fast and at what weight does that 900HP b1-BS run or is this another FANTASY dyno post?
Re: Some B1 Original pics......... [Re: Biginchmopar] #105653
12/09/11 01:16 PM
12/09/11 01:16 PM
Carson City, Nevada
Carson City, Nevada
For the non believers on the B1-BS heads:
First the heads have been worked big time by EPD (Larry Olson). A max Wedge port (kind of) with a 2.250" intake and a 1.800" exhaust, 60cc chamber.
Injected on Alky, tunnel ram, 2-2 1/8" Injectorators.
Final compression is 15.3:1
498CID
When I find the dyno sheet I will scan it and post it. I was just trying to get the fuel curve close so I didn't push every last drop out of the motor on the dyno. I know one pull it made 867hp @ 6500rpm, the motor is supposed to go 7500rpm easy and there was no drop on the HP curve @ 6500.
Re: Some B1 Original pics......... [Re: Biginchmopar] #105654
12/09/11 07:55 PM
12/09/11 07:55 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Has anyone converted to push rod oiling using the older style T&D rockers??
Alan Jones
Re: Some B1 Original pics......... [Re: Biginchmopar] #105655
12/09/11 08:12 PM
12/09/11 08:12 PM
Syracuse,NY
Syracuse,NY
Biginch,
What made you go with the BS heads for that combo. The BS head is a good little head,but takes a lot of work to get their full potential, which can be much easier obtained with other heads. My last BS heads went on a boat out in california. A great velocity head. How much camshaft? Look forward to seeing how they run in your combo.
RIP Monte Smith
Re: Some B1 Original pics......... [Re: CompWedgeEngines] #105656
12/10/11 10:39 AM
12/10/11 10:39 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Biginch,
What made you go with the BS heads for that combo. The BS head is a good little head,but takes a lot of work to get their full potential, which can be much easier obtained with other heads. ...Look forward to seeing how they run in your combo.
I will continue the post high-jack. More questions for BigInch...
First I don't doubt anymore that power from a MAX effort deal such as yours. But,I'm curious too why you choose that head for 750+HP because as Comp pointed-out there are other options? Are you sure EPD used 2.25" valves because every BS head I've seen had too small an insert to accomodate that size valve $$$. I'm not sure you meant your first post to read the way I read it but, it reads (to me)as-if it was as easy as pie (cheap too) to slam that piece together. Hope you didn't use the supplied BS rocker$. My point is that if you throw enough money (time/resources) at any head you'll make power.
Re: Some B1 Original pics......... [Re: HardcoreB] #105657
12/10/11 11:03 AM
12/10/11 11:03 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
For 2.25 valves in b1-bs heads, you will have to change seats also. I almost had this done, but went with B1 originals instead.
Still got the seats and valves for the job.
Re: Some B1 Original pics......... [Re: RT540] #105658
12/11/11 06:02 PM
12/11/11 06:02 PM
Carson City, Nevada
Carson City, Nevada
Why the B1-BS, because I had the heads. I agree a B1 would have been a better choise but I'm sick. I do have another engine for the car and it will be a bad ombray. I have T&D rockers that are pushrod oiled (bushed lifter bores). The other reason was Indy said you can't make a B1-BS head run with a Indy -1 (WRONG!)
I like it when people say (you can't do that).
Like I said the heads have been worked on alot and I'm either stupid and sick or dertermined and broke either way I did enjoy seeing the motor make real good power.
I have a 596 predator motor for the next project and then the car will go to A/Gas (7.60)
Anyway I love seeing B1 builds that is why I looked at this post in the first place. Sorry for a slight hijack. Keep up the good work.
Re: Some B1 Original pics......... [Re: Biginchmopar] #105659
12/12/11 04:23 AM
12/12/11 04:23 AM
Carson City, Nevada
Carson City, Nevada
Just to clear the water a little more, yes 2.250" Intake valve. Not as much work as it sounds we also thought about welding up the spark plug hole and putting it in a different location (angle plug) but we left that for latter if needed. The motor made more than I though it would but was no easy task. I never just bolt things togerther the way they come out of the box.
Re: Some B1 Original pics......... [Re: Biginchmopar] #105660
12/13/11 06:06 PM
12/13/11 06:06 PM
LA360 Offline
LA360  Offline
just to keep this up there
Alan Jones
Re: Some B1 Original pics......... [Re: LA360] #105661
12/14/11 03:00 PM
12/14/11 03:00 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
still waitin to hear from that fellow in Brisbain. He was flipped over the car when he got it, he was like "pinch me" am i dreamimg? lol
said he would send some vid...are U guys racing down there right now?
cheers dave
Re: Some B1 Original pics......... [Re: B1Fish540] #105662
12/16/11 09:05 PM
12/16/11 09:05 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Some B1 Original pics.....**UPDATED** AGAIN** [Re: Brian Hafliger] #105663
07/07/13 11:23 AM
07/07/13 11:23 AM
Colorado
506RR Offline
506RR  Offline
Colorado
Mods, can this thread be added to the archives?
Re: Some B1 Original pics.....**UPDATED** AGAIN** [Re: 506RR] #105664
07/07/13 12:16 PM
07/07/13 12:16 PM
Wisconsin
Jet Doc Offline
Jet Doc  Offline
Wisconsin
Since this was brought to the top. Here are a couple shots of my B1 originals after CNC porting
