CAL TRAC PRELOAD QUESTION #1056438
08/18/11 11:52 PM
08/18/11 11:52 PM
Wi.
old_racer Offline OP
Wi.
Hi,
was racing at the Nats and a guy came up to me and asked how I had my cal tracs set, I have the whole set up, they're mono spring etc. rancho shocks, I'm a 11:00 nostalgia SS car, my car's best is around 1.46 .60ft, most of the time around 1.49 to 1.51, during class run off with similar cars et, I look at others .60ft and mines good if not better than theres. any way the guy said he talked to another racer who's running good and has 2 turns of preload on his bars, and I'm running with about 2 flats on the bars, two full turns seems like a lot. it seams like it would bend the springs quite a bit to get 2 full turns on the bars. just wondering what others use and what works for them. maybe I'm missing something.
thanks
Russ
Re: CAL TRAC PRELOAD QUESTION [Re: old_racer] #1056439
08/19/11 12:11 AM
08/19/11 12:11 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I got 2 flats on the left....4 flats on the right. Seems to hook the best there. 3700# Challenger with 1.46-1.47 to 1.52-1.53 depending on the track. Hits the tire hard. Ranchos on 8.
Re: CAL TRAC PRELOAD QUESTION [Re: superwrench] #1056440
08/19/11 02:38 AM
08/19/11 02:38 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
i have a 1/4 turn each side,as per a call to Caltracs.
pulls straight,never had cause to try anything else
i have found the ranchos work best for me on #9,1.54-1.57 60
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: CAL TRAC PRELOAD QUESTION [Re: tex013] #1056441
08/19/11 08:46 AM
08/19/11 08:46 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Once you have your side to side set up and done trying different pre loads is part of the tuning you do for your car. what it likes. There is some nhra stockers that put up to 2 full turns of preload after it was set up.
JAKES AUTOMOTIVE
Re: CAL TRAC PRELOAD QUESTION [Re: old_racer] #1056442
08/19/11 11:17 AM
08/19/11 11:17 AM
an8sec70cuda Offline
I only run a 1/4 turn on both sides. Bottom hole, shocks on 9.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: CAL TRAC PRELOAD QUESTION [Re: old_racer] #1056443
08/19/11 11:43 AM
08/19/11 11:43 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IIRC, 1/2 p-l on driver side, 1/2 + 1/3 on passenger side, 5-way Ranchos on #3, bottom hole ==> 1.45-1.46 60-fts on 275/60R15 ET Street Radials.
Re: CAL TRAC PRELOAD QUESTION [Re: an8sec70cuda] #1056444
08/19/11 11:45 AM
08/19/11 11:45 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
At beech bend, I changed from 2 flats on rt. side to having the pin just touching the spring on both sides with drivers weight in and motor running when setting them. I was 1.44-1.47 with the car "detuned"
Re: CAL TRAC PRELOAD QUESTION [Re: JAKE68] #1056445
08/19/11 12:11 PM
08/19/11 12:11 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
This will soften up the hit I assume,,,
Sounds like it varies alot with the individual car,,,
I have heard leave a "nickel" size air gap,,,all the way up to lots of preload...as far as ways to adjust them.
Jake, ( and Jim ) ,,what are you running for rear tire pressure ?
thanks,
Doug
Re: CAL TRAC PRELOAD QUESTION [Re: 69CHARGERMD] #1056446
08/19/11 02:25 PM
08/19/11 02:25 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
We run about 14.5lbs. WE have right now with driver 1/2 turn preload with 35lbs more on right side. 3550#w dr. 1.29 60's 10.5w
JAKES AUTOMOTIVE
Re: CAL TRAC PRELOAD QUESTION [Re: superwrench] #1056447
08/19/11 02:44 PM
08/19/11 02:44 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
When running that much preload you should switch to the upper hole and start flush! Upper hole hits the tire the hardest . The hardest you can hit a tire with caltracs is top hole and lots of pre load .. Lower hole no pre load is the softest ...
Mopar Performance
Re: CAL TRAC PRELOAD QUESTION [Re: an8sec70cuda] #1056448
08/19/11 02:50 PM
08/19/11 02:50 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Chip I think it was you that asked over winter about switching to double adjustables vs the single ranchos! Best I got with ranchos was 1.46(not many passes before lifter broke) and first time with the afco doubles was 1.40 on bottom hole and same preload! Flush on drivers side and 2 flats pass side... I'd love to tune this thing up your 60s
Mopar Performance
Re: CAL TRAC PRELOAD QUESTION [Re: 69CHARGERMD] #1056449
08/20/11 08:34 PM
08/20/11 08:34 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
thanks,
Doug
Doug,
I run between 12.5 and 13.5 psi, M/T 29.5 x 10.5 bias
20-24 psi when running hoosier 30x9 radials and yes the radials are about tenth quicker!
Re: CAL TRAC PRELOAD QUESTION [Re: nss guy] #1056450
08/20/11 08:45 PM
08/20/11 08:45 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Thanks Jim,,,,
I was running 14 lbs,,,but the car was "on ice" off the line,,,dropped it to 12 lb,,,and it took care of it,,,thanks,,,,see ya at Norwalk.
ps,,nice sig pic.
