Will swapping my orig. tors. bars help my 60'?? #1056405
08/18/11 10:31 PM
08/18/11 10:31 PM
Cleveland
sunroofgtx Offline OP
Cleveland
Looking to swap my orig torsion bars to a "better" pair. Is there a street/strip that my 3900 lb GTX would like. My short time best is 1.60. 10.89 @ 126. Thanks. I've got Cal Trac rear mono's with 9 way Rancho's, and Calvert front's as well..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Will swapping my orig. tors. bars help my 60'?? [Re: sunroofgtx] #1056406
08/18/11 11:00 PM
08/18/11 11:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rich... it would depend on what bars are in it now
and how much travel you have... if you went with a
lighter bar you will get more stored energy in the
bars to lift higher VS a big bar that lifts only so
much then stops lifting.... either way you need the
travel
Re: Will swapping my orig. tors. bars help my 60'?? [Re: MR_P_BODY] #1056407
08/18/11 11:19 PM
08/18/11 11:19 PM
Cleveland
Cleveland
Thank you , Mike. I have it's stock GTX 120,000 mile bars in it.
Re: Will swapping my orig. tors. bars help my 60'?? [Re: sunroofgtx] #1056408
08/18/11 11:26 PM
08/18/11 11:26 PM
New York, USA
Chargerfan68 Offline
New York, USA
You have Caltracs in the rear...and they require 5-5 1/2" of travel up front. The thinner /6 or drag bars would definitely lower the front of the car down some to allow more travel, and like said, give you more stored energy for the launch.
With caltracs and the power you are producing, you should be well in the 1.4s 60 ft.
Check and see how much ft. end travel you have to see if the setup can work as intended.
Good luck,
Greg.
Re: Will swapping my orig. tors. bars help my 60'?? [Re: Chargerfan68] #1056409
08/19/11 12:43 PM
08/19/11 12:43 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Depends on road usage, i wouldn't use lighter than 318 bars on your car, my bars are sl 6 and they struggle with weight of the 440 over the nose in a 3200# race ready car.
My car dropped .14 changing from 340 GTS bars to sl 6.
Wallace calc says a 10.89 = 1.51 60ft and 126 mph =10.52
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Will swapping my orig. tors. bars help my 60'?? [Re: deaks] #1056410
08/23/11 12:12 AM
08/23/11 12:12 AM
Cleveland
Cleveland
What about Mopar specific Drag Racing bars? Any luck? I want new bars, just want to maximize my set-up.
http://www.arengineering.com/articles/tbartango.html
