Re: Will swapping my orig. tors. bars help my 60'??
[Re: sunroofgtx]
#1056406
08/18/11 11:00 PM
08/18/11 11:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Rich... it would depend on what bars are in it now and how much travel you have... if you went with a lighter bar you will get more stored energy in the bars to lift higher VS a big bar that lifts only so much then stops lifting.... either way you need the travel
[Re: MR_P_BODY]
#1056407
08/18/11 11:19 PM
08/18/11 11:19 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Thank you , Mike. I have it's stock GTX 120,000 mile bars in it.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1056408
08/18/11 11:26 PM
08/18/11 11:26 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
You have Caltracs in the rear...and they require 5-5 1/2" of travel up front. The thinner /6 or drag bars would definitely lower the front of the car down some to allow more travel, and like said, give you more stored energy for the launch.
With caltracs and the power you are producing, you should be well in the 1.4s 60 ft.
Check and see how much ft. end travel you have to see if the setup can work as intended.
Good luck, Greg.
[Re: Chargerfan68]
#1056409
08/19/11 12:43 PM
08/19/11 12:43 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Depends on road usage, i wouldn't use lighter than 318 bars on your car, my bars are sl 6 and they struggle with weight of the 440 over the nose in a 3200# race ready car. My car dropped .14 changing from 340 GTS bars to sl 6. Wallace calc says a 10.89 = 1.51 60ft and 126 mph =10.52 Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
