Re: Do I need larger tube headers???
[Re: roadhazard]
#1056311
08/18/11 05:40 PM
08/18/11 05:40 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What times does the car run?. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: vttm]
#1056312
08/18/11 05:46 PM
08/18/11 05:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Takes more than just a couple of numbers to make that choice ... if you want PM me and I'll send you some data to fill out and I can run it through my header program
[Re: deaks]
#1056314
08/18/11 06:03 PM
08/18/11 06:03 PM
Posts: 188 MD.
vttm
MD.
Mainly a street car but last year ran 10.30's at 128 with fuel and chassis problems got those fixed now but I havent had a chance to go yet this year.
[Re: Mr.Yuck]
#1056315
08/18/11 06:08 PM
08/18/11 06:08 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I am also running 1 7/8 hooker super comps. 3" collectors. 499 rb 12.5 to 1 comp. 275 solid roller, stage VI heads and intake, 1050 domi. I have thought about this alot also. But is the gain worth the dollars? I guess the big question is, How much gain?
67' charger 499 RB
10.57 at 127
[Re: racerx]
#1056317
08/18/11 06:22 PM
08/18/11 06:22 PM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
generally a 1 7/8" with a converted 3 1/2 collector (std is a way too small 3") works better overall (in terms of average torque) than a 2" with an auto when the stall speed is below the torque peak. But you have deep gears so it's probaly not a bad move. In a lighter car it matters a lot less.4500 stall is about where a 2" pays off but IMO 90% of the gains on a std wedge port size is the larger collector that comes along with it. Anybody who says you have to have a 2" + primary to go fast should attend a F.A.S.T race They're going high 9's running manifolds and dual 2 1/2" pipes though full exhaust systems.....though I suspect some may now be running 70mm (2.75" Euro spec) pipes but nobody's caught on cause they look like 2 1/2" Once a tech director...always a tech director
[Re: Sport440]
#1056319
08/18/11 06:37 PM
08/18/11 06:37 PM
Posts: 4,073 Mo.
racerx
Mo.
He stated the car weighs #3400
Id use the headers you have with the 4500 stall.
ooh.just re-read the post ..My fault
