440 source Stealth heads and RPM intake: porting Qs?
#1056269
08/18/11 03:27 PM
08/18/11 03:27 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Hi!
I just finished bowl blending and port matching the intakes on my stealth heads and Eddy RPM intake.
I just blended the valve seat cuts into the bowls, left the guides bosses alone as I thought they were already very slim as cast, I port matched the intake ports to the intake gasket, and port matched the RPM intake a tad smaller than the intake gasket scribe lines to leave a bit of room for missaligment issues.
I also ground off any casting flash and irregularities from the intake and exhaust ports on the heads and intake.
Thats it.
How much do you think I have picked up from doing this, and do you suggest I go any further?
This is a stock stroke 440, 10,5:1 CR, and a hyd flat tappet cam with around ,530 lift.
Im gonna use stock HP 70-71 exhaust manifolds and a full 2,5" exhaust.
Re: 440 source Stealth heads and RPM intake: porting Qs?
[Re: domingo]
#1056270
08/18/11 04:30 PM
08/18/11 04:30 PM
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1056271
08/18/11 06:44 PM
08/18/11 06:44 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
My opinion on the work you did is this: you just guaranteed the advertised flow, perhaps a little more, and then you put a cork in the system with stock type manifolds/exhaust. You may be losing 30 to 60 hp potential on the conservative side.
Absolutely nothing wrong with that if that is the direction you want to go.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
