New Heads On A Used Engine #1056152
08/18/11 02:23 PM
08/18/11 02:23 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
What's up, all. I've always heard that putting new heads on a used engine would cause it to mess up sooner or later. Is this an old wives tale or no? TIA for any help.
Re: New Heads On A Used Engine [Re: 440child] #1056153
08/18/11 02:41 PM
08/18/11 02:41 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Never heard that one, or had a bad experience doing it. Short block will wear on out sooner or later. That isn't to be unexpected.
I want my fair share
Re: New Heads On A Used Engine [Re: 440child] #1056154
08/18/11 02:46 PM
08/18/11 02:46 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
That is an OWT !
But if the short-block is worn-out ...and the heads are high-$$ .. that is kind of a waste.
Re: New Heads On A Used Engine [Re: BeEtLeJuIcE !] #1056155
08/18/11 02:51 PM
08/18/11 02:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i swear my old wife never said that, and trust me, the 'tail' is long gone!
Re: New Heads On A Used Engine [Re: mikemee1331] #1056156
08/18/11 02:54 PM
08/18/11 02:54 PM
Florida STAYcation
Florida STAYcation
old wife ? ... and no-tail ? ... ...
Re: New Heads On A Used Engine [Re: BeEtLeJuIcE !] #1056157
08/18/11 03:09 PM
08/18/11 03:09 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Don't they both go hand in hand?
Re: New Heads On A Used Engine [Re: mikemee1331] #1056158
08/18/11 05:07 PM
08/18/11 05:07 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
Maybe I should have used the word 'myth' instead.
Re: New Heads On A Used Engine [Re: POS Dakota] #1056159
08/18/11 05:11 PM
08/18/11 05:11 PM
Florida STAYcation
Florida STAYcation
hand-in-hand ? ... ..
Re: New Heads On A Used Engine [Re: 440child] #1056160
08/18/11 05:15 PM
08/18/11 05:15 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
around here it is always wise to choose your words (and spell them right) or the flames get flyin' and the wise cracks get crackin'! all in all we're pretty harmless and in desperate need of lives!
Re: New Heads On A Used Engine [Re: mikemee1331] #1056161
08/18/11 10:13 PM
08/18/11 10:13 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
if your old wife see,s this ...no tail for you... hahahahaha dan
Re: New Heads On A Used Engine [Re: ph23vo] #1056162
08/18/11 10:21 PM
08/18/11 10:21 PM
FT. Worth TX
P
PASTLITE Offline
PASTLITE  Offline
P
FT. Worth TX
Never had a problem with any. Heard that years ago.
Last one I did block had over 280,000 miles on it.
Re: New Heads On A Used Engine [Re: PASTLITE] #1056163
08/18/11 10:29 PM
08/18/11 10:29 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Hot new heads make you want to beat on an engine
If the short block was marginal, you'll hasten its demise by beating on it (old heads or new).
If the short block was solid, it should live just fine.
My 75k mile OE short block is living fine at this point with a fresh set of ported Magnum heads, but I'm only around 3000 miles on the combo... you'll have to check back with me!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: New Heads On A Used Engine [Re: 440child] #1056164
08/18/11 11:03 PM
08/18/11 11:03 PM
scratchnfotraction Offline
its a chebby thing
but it comes from the idea...if you shave to raise comp ratio,do a valve job so seals up the cyl good.
the used and worn rings will have more blow-by from the pressure in the cyl.
comes from chebby guys explaneing why they have blow-by on their re-ring amd dingleberry hone job
my 360 head 318 cop engine is a 88 and never had the heads off yet,I added a roller cam in 07' , its been by me for over 10 yrs now
I know why i cant tune the miss out,and know why it blows 2 qrts oil a week,and know why its low on power...it worn out!
I think I could prove the myth if i just did a valve job and left the rings as is at this point...it well over 300,000 miles
run what ya brung
Re: New Heads On A Used Engine [Re: scratchnfotraction] #1056165
08/18/11 11:12 PM
08/18/11 11:12 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I used to think it was BS until I saw it happen.
My dad had a 1980 Crew Cab dually with a 360. This was 2003-2004 or so and it only had 70K miles on it, it had a fair sized cam in it and doug thorley headers. It had been used alot as a tow vehicle and it picked up a miss and it turned out to be a bad exhaust valve. Well I tore it down and he had the heads redone. I put it all back together and fired it up. I warmed it up and shut it down, I had some things to take care of on it so I retightened some things and tried to fire it back up. It cranked like it had no compression and would barelly try to fire. Kind of stumped I called it a day. Well my dad messes with it and figures out it will start if you put oil in the cylinders and it will kind of run...run like it doesn't have any compression. Soooooo it can happen even if you think it is BS lol.
68 Barracuda Formula S 340
Re: New Heads On A Used Engine [Re: Bad340fish] #1056166
08/18/11 11:28 PM
08/18/11 11:28 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Sounds like the rocker arms are not adjusted correctly, or the maybe the valve job wasn't done right and the valves aren't touching the valve seats all the way.
Re: New Heads On A Used Engine [Re: Neil] #1056167
08/19/11 01:14 AM
08/19/11 01:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
lower end rebuild fixed it
Re: New Heads On A Used Engine [Re: Bad340fish] #1056168
08/19/11 08:55 AM
08/19/11 08:55 AM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
Thanks for all the replies!
Re: New Heads On A Used Engine [Re: 440child] #1056169
08/19/11 04:35 PM
08/19/11 04:35 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I put a set of aftermarket heads onto an old 440 bottom end that I did an el cheapo hone'n're-ring job one. It ran great after I was done!
Re: New Heads On A Used Engine [Re: DaytonaTurbo] #1056170
08/20/11 01:27 PM
08/20/11 01:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There is a bit of truth to the story. If the engine is wore out enough to need new heads then the rest of it is probably on it's way out too.
If you ONLY fix the heads why would it surprise anyone the rest of the worn out engine gives up the ghost not too much later?
Common sense.
Don't be the exception.
Re: New Heads On A Used Engine [Re: Supercuda] #1056171
08/20/11 04:21 PM
08/20/11 04:21 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My understanding is that if there were no defects in manufacturing, the engine parts usually wear at the same rate. A high mile engine that uses oil and smokes does so because ALL parts are worn. Bolt on fresh heads that seal better and the stressed piston rings are under a greater load and the oil burning actually can increase.
I had a 360,000 mile 305 in a Chevy truck that still ran great and passed CALIFORNIA smog, but 2 exhaust manifold bolts broke off flush to the head causing an annoying leak. I had a pair of 350 heads freshly rebuilt for another project, so I swapped them over since I needed to keep this daily driver operational and smog compliant. The motor actually LOST power with the new heads and the motor spun 3 rod bearings 10,000 miles later. I should have just rebuilt the whole motor instead of replacing the heads, but I only had a weekend to make the changes. Still, 370,000 miles from ANY gas engine is impressive.
