Need to touhgen up my bottom end ....
#10547
05/03/04 05:50 AM
05/03/04 05:50 AM
Since I'll be down over the summer due to the new arrival (XY) in early June, I was considering building something that has a little more umph over the summer .... OK a lot more umph. I'm considering a Nitrous Engine that I can still bracket race Normally Aspirated. I have two good seasoned RB blocks ('66 and '68) and a set of Manley H Beams OEM (2.375/1.094) on each end. I'd like to survive 725-750HP NA with a 150-300HP shot w/ annual teardowns between seasons. 1. Aluminum Caps, Billet Caps or 4 Bolt Conversion? 2. Fill the RB block to where? Bottom of the freeze plugs or higher?
Re: Need to touhgen up my bottom end ....
#10548
05/03/04 07:44 AM
05/03/04 07:44 AM
will it be driven on the street? ?
#10549
05/03/04 08:19 AM
05/03/04 08:19 AM
Seldom. I like to take it 15 miles to a local car show once a year and a few family cruise-abouts a year. Maybe 200-500 miles. Everything else is on or in the trailer.
[Re: B1Ken]
#10551
05/03/04 01:12 PM
05/03/04 01:12 PM
Thanks Ken - I'd really like to stay Raised Block, but I understand the inherent risks. Although, IF I went B Block for some Big power, I'd be looking aftermarket since most original blocks I've looked at are no bargin with the work that they'd need. B Block Post
#10552
05/03/04 01:37 PM
05/03/04 01:37 PM
i would do a 1/2 fill, run the steel main caps, run your rods, & good set of rings w/ the end gaps set for the nitrous, watch the cam selection w/ the added cylinder pressures you'll run, have a good ignition system/ rpm limiters, if you don't already, an rb block will work fine, for added strenghth in the bottom you could add the girdle from gears & rears ( member name i forgot)
#10553
05/03/04 01:49 PM
05/03/04 01:49 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
if you are going to the expense of the dvorak girdle wait and get a megablock ..
[Re: JohnRR]
#10554
05/03/04 01:57 PM
05/03/04 01:57 PM
I was looking to get something to tide me over and add a margin of safety w/o alot of effort. I need to be back in business Mid August - Early Sept for shakedown to get ready for some FALL racing and some cooler weather Anyone using the Girdle from Gears and Rears? Looks simple, even for me.
#10555
05/03/04 06:16 PM
05/03/04 06:16 PM
Posts: 1,278 Mission BC
10sec440
Mission BC
Be careful when buying a girdle. I bought one last year and about all it's good for is an expensive paper weight.The #5 main cap nuts are right in the way of the oil pan rail. Be prepared to modify the oil pan for this.If anyone wants it, it's for sale.
#10556
05/03/04 06:49 PM
05/03/04 06:49 PM
725-750 HP may or may not last with either block. dvoraks girdle would help the most out of what i've seen though. i have my own idea's on what i would build, but sorry to say it probably wouldn't include the manley rods you already have. i hope you have some real good cylinder heads too.
#10557
05/03/04 07:29 PM
05/03/04 07:29 PM
I'm not 100% fond of the rods now either, but kinda stuck with them for right now. There's not enough room for the Aluminum variety by my calculations unless I notch the pistons again. I'll call CP for some advise there. If you have any ideas, let me hear them, I'm all ears.
I'm not points racing this year, so I'm spending some time and effort learning about making some more power! I'm working on a Head/Induction package .... so I can spend "some" of my hard earned Navy retirement $$s wisely.
I ran across the fragment of "THE 23mm round" I keep for a reminder on the value of life a few weeks back. I guarantee I'll "outlive" most everyone out there. Whether I die before they do or not, is completely debatable. The spousal unit said I needed something to keep my mind occupied throughout the summer that keeps me home, and thus, the genesis of a new combo.
#10558
05/03/04 07:38 PM
05/03/04 07:38 PM
Harpo, I ran a 446 with aluminum caps on a stock block with B1/BS heads 2years ago. I ran the motor for two seasons. I don't remember how many runs. It was making around 700HP with a tunnel ram. I had picked up 4.15 crank and was going up to 493cu.in. When I tore down the motor for the change I discovered one of the aluminum mains broke! After considering the cost of changing over to 4 bolt program steel caps and line boring the block, I bit the bullitt and bought a Mega block. I know there are no quarantee's with race stuff, but I felt it was money better spent. especially, if I want to make more power. Fast68Plymouth helped me put together a 528 that made 750HP with 720TQ. The bigger motor made all it's grunt down low. I switched from 4.56's to 4.10's. I shift @ 6000 and go out the back @ 6800. I feel like I am not even beating on this thing. Just my 2 cents!
[Re: 10sec440]
#10559
05/03/04 08:13 PM
05/03/04 08:13 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
10sec440, was this one of mine?? With our design, the #5 location on the girdle has holes for stud clearance only and comes with two short studs for the #5 location only. All other studs are extra long and will clear even stock pans. The three center caps and the front cap are all you can tie to the girdle without pan modifications to clear. Mike
#10560
05/03/04 10:30 PM
05/03/04 10:30 PM
Harpo, it was brought to my attention that what i posted earlier could be misinterpreted. i want to clear up the statement about the rods. the reason i wouldn't use those particular rods is because of the big and small end size, for starters. to make the HP you want to make, i would be looking to slow down the bearing speed with a 2.200" journal instead of the 2.375". naturally i would want to lighten everything up and that would include going to a .990 pin. i didn't mean to imply that because the rods were manley's that i owuldn't use them. sorry if there was any confusion. Dan
#10561
05/03/04 11:36 PM
05/03/04 11:36 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Harpo, As you know from other posts I've answered, I really think the RB block is more than capable of what you're asking from it..I went the Aluminum rod/ Aluminum Cap route with mine, also with 2.375/1.094 ends. and rocked the block all the way to the bottom waterpump hole. While I doubt that I'm making as much power as you motor for motor...I have successfully smacked mine with 425 HP of spray 10-20 times, and have 310 passes on the engine now without any problems. I have purchased a set of 4 bolt pro-gram caps (the three center ones) but have yet to install them on a block. I have seen a few broken stock and aluminum caps..usually the cracked caps are found before any major damage ensues...not that thats any consolation!!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
#10562
05/04/04 04:52 AM
05/04/04 04:52 AM
Harpo, it was brought to my attention that what i posted earlier could be misinterpreted. i want to clear up the statement about the rods.Dan
No confusion on my part Dan. They're good rods for the right application. I got these rods effectively for FREE. Otherwise, I'd have had a 4.15 stroke with 2.2/.990 deal going. Unfortunately now, the CP pistons are 1.094 as well. It goes to show you, even FREE stuff has a cost. Ahhh, If I had it to do over again ...
I guess I could shelf the Manley/CP combo, grind the crank to 4.25/4.30 and go with a 2.2/.990 rod/piston combo.... but then, I'd feel like I'd really need to step up the block. Originally, I was just looking for some "bolt on" performance, not a $6000 upgrade for this one. I know I'll be missing something with 2.375/1.094, but that's just what I'll live with to keep testing somewhat portable for others. Change too much, and there's no way we'll understand WHY it picked up.
Just trying to save a good block. As it is, we'll probably need a little honing and rings if we do a partial fill. If we're that far, maybe Aluminum Caps/Line Hone are the way to go for now. I'm on the fence. The girdle looks appealing, but if I already have the block apart, does it gain me aything more than good aluminum caps and line hone would if you set price aside as a consideration? Could I skip the Block Fill with the girdle?
#10563
05/04/04 09:27 AM
05/04/04 09:27 AM
MoparBilly
Phoenix, AZ
I will probably open another can of worms even worse than questioning the weight of Montessa's Charger...but I've filled 3 blocks so far...after machining, with no adverse affects. My machinst does my work for free, (what were you saying about free stuff having a cost, Harpo?)and flat out refused to rock them first. The water temp is actually easier to control ith a filled block, but I guess oil temp can be a problem in an application that sees extended run time.
[Re: MoparBilly]
#10564
05/04/04 12:48 PM
05/04/04 12:48 PM
Hmmmm .... fill the block, add the girdle .... is it too good to be true to keep me safe for 300-400 passes w/ teardown at 150-200?
#10565
05/04/04 02:20 PM
05/04/04 02:20 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
I like the 4.30 stroke idea, if you're gonna spray it I'd go with the 7.100" rod, It gives you a ~1.46CH piston, @514 cubes and the rod angularity will be a little easier on the thrust sides of the block on a spray combo. I'd probably forgo the girdle, go with steel caps and a fill to the freeze plugs. Depends what you plan for heads but I wouldn't mess too much with the tree side of the track, you've got solid, consistent and quick and at that weight that's a tough thing to nail. My idea would be keep the consistency while easing down the ET's in the first 1/8th with a little added torque/CR and hp. Spray it with a 250 shot on a 1-2/10th sec time delay relay triggered right after you're in high gear, (I like a microswitch right of the shifter detent to the TDR in series with a WOT switch), that'll be easier on both the motor and the trans and you'll be on the spray down the whole big end of the track with consistency and not tearing anything up too bad. Going sub 6.50 in the 1/8th can be snuck up on, that's ~10.20 without the spray, let the bottle pick up the big end load. Heavy cars usually break motor parts right off the line, this way you've got kind of like a "Hemi in a bottle" with the big end charge. Like they say if you can hear a hemi at half track...he's got you!!
Also, if he or you red light or are comatose on the light, you save the juice. Besides you'll still be within the stress levels of the block on every launch, should last a good long while.
This way, I think you could go high 9's without either tearing things up or having to re-science your whole set-up.
#10566
05/05/04 01:30 PM
05/05/04 01:30 PM
fast68plymouth
So. Burlington, Vt.
in an application like yours the 2.375/1.094 rod combo doesnt bother me a bit(thats whats in the 528 BTW).
my .02 .....tall fill in the block, install the 3 middle steel caps, hope for the best and run with it.
