converter stall to rpm shift point #1055237
08/18/11 12:48 AM
08/18/11 12:48 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
is there an rpm spread that is ideal?
Re: converter stall to rpm shift point [Re: sixpackgut] #1055238
08/18/11 03:01 AM
08/18/11 03:01 AM
Probally but every motor and converter may not be the same, my T/A 8 inch drops down to 5700 RPM if I shift it at 6000 up to 7000 RPM, if I shift it above 7000 RPM if will drop down to 5800, to 6000 RPM depending on from first or second. I run the Mopar brand 2.77 low 1st gear set so the RPM drop is more than with a stock standard 2.45 low gear set I have always operated on the theory that you have to go to the tarck and find out where to shift each combination by testing it IHTHs
Re: converter stall to rpm shift point [Re: Cab_Burge] #1055239
08/18/11 09:47 AM
08/18/11 09:47 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Define "Ideal"??
We used to have a loose 8" that would stall 52-5400 behind the typical junkyard 284-484 440. You know, the kind of motor that was all done at 5800! 400-600 rpm is definitely not ideal, but it sure was fun!! It would usually be a tenth quicker, and 2 mph slower than the common 10" 3600.
If it's strictly a race car, especially a heavy one, how well the converter and torque curve match, may determine a lower shift point rather than raising the stall. 10% above peak torque rpm used to be the rule of thumb for stall setting, but I think modern agressive converters can be a little closer to peak, and deliver the best performance.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: converter stall to rpm shift point [Re: sixpackgut] #1055240
08/18/11 10:13 AM
08/18/11 10:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ideal I use 1500 rpm... I dont know if its
the best but that works for my set up so I dont spend
to much time at the stall point on the shifts
Re: converter stall to rpm shift point [Re: MR_P_BODY] #1055241
08/18/11 10:28 AM
08/18/11 10:28 AM
Charleston
Charleston
1500 is what i was thinking. 5000 stall shift at 6500.
right now i have a 5300 and shift at 6800 but i havnt tried anything else
Re: converter stall to rpm shift point [Re: Cab_Burge] #1055242
08/18/11 10:36 AM
08/18/11 10:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would be thrilled with 1500 rpm, cant seem to get anyone to get one that loose. Gonna have Figueroa cut one open and give it a try. The last two stall at 6400 and 6200 respectively and running all out I shift at 8200 With a glide in the car it is killing the ET all out.
Re: converter stall to rpm shift point [Re: sixpackgut] #1055243
08/18/11 10:46 AM
08/18/11 10:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mines a little low right now with the W-9 but worked
fine with the W-2... its 5600 stall and I shift at 7800
and hit the traps at 8100-8200 on the W-9
Re: converter stall to rpm shift point [Re: MR_P_BODY] #1055244
08/18/11 11:13 AM
08/18/11 11:13 AM
Renton Washington
Triple Threat Offline
Renton Washington
Mine flashes to 4600 and the shift light comes on at 5800.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: converter stall to rpm shift point [Re: MR_P_BODY] #1055245
08/18/11 12:43 PM
08/18/11 12:43 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
That's what I've been told repeatedly from many sources.
But I am not doing it since my truck is street driven.
Using a 3800 stall in my truck and a 6200 rpm shift point.
I doubt it will really suffer any. Or should I say I wont be missing anything.
