BB A Body Torsion bar
#1055188
08/17/11 10:56 PM
08/17/11 10:56 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
A body guys, what torsion bar you running with a BB?
and can someone tell me the diameters of the A body bars? think i have /6 and maybe want to go SB
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: BB A Body Torsion bar
[Re: moparniac]
#1055190
08/17/11 11:19 PM
08/17/11 11:19 PM
sixpackgut
Charleston
Sledgie, what did you have? i'm goin to measure mine now
[Re: sixpackgut]
#1055191
08/17/11 11:19 PM
08/17/11 11:19 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Id recommend the 318 bars with a BB. Thats what I use and love them. They are a little stiff for me because Im so light at 3000# but work great. You can ID your bars by both the diameter and the identifying stamping numbers on them. /6 bars are .83 diameter, stamped 889. on both sides. 318 bars are .85 diameter, stamped 890/891 R/L 340 bars are .87 diameter, stamped 892/893 R/L
[Re: Sport440]
#1055192
08/17/11 11:39 PM
08/17/11 11:39 PM
sixpackgut
Charleston
mine are .830
i'm thinking i want to put small block bars in the car, limit front end to 2" of lift with a ladder susp. what do you think?
just took the car for its first ride and the front is dragging and i dont have much adjustment left
doesnt look to bad in this pic but it got worse
[Re: sixpackgut]
#1055193
08/17/11 11:43 PM
08/17/11 11:43 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I have the stock 1971 6 non air cylinder bars in my Duster, I also ended up using the Koni SPA B body front shocks 1.41 60 ft. cork up so far It is street driven and rides fine this way
[Re: sixpackgut]
#1055197
08/17/11 11:52 PM
08/17/11 11:52 PM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
I've always used the 340 bars with my big block. I've never had a hooking or handling issue. I run a small tire and leaf springs with cal-tracs. My car consistently goes 1.3 to 1.33 60fts.
It's a bigblock with a torque flight!!!
[Re: sixpackgut]
#1055198
08/18/11 12:05 AM
08/18/11 12:05 AM
Sport440
Canton, Ohio
mine are .830
If you want the limited travel like you do, then you will want the thicker 340 bars or thicker. How heavy are you?
@ 3000# my 318 SB bars are pretty stiff, but I still get 4" to 6" of front end lift or so. Your 2" lift max wont work IMO unless your some kind of chassis Guru.
[Re: Sport440]
#1055200
08/18/11 12:14 AM
08/18/11 12:14 AM
sixpackgut
Charleston
mine are .830
no chassis guru, poor bob george had to answer 100 questions while i was attempting to weld this car together.
the more i watch fast cars go down the track the more i notice how even and uneventful their cars look while us slow guys are trying to put it on the bumper and act like mental patients.
i never had a ladder bar car so i dont know but i have only heard that "5 inches of travel" needed for the caltracs. i dont hear ladder bar guys saying that
[Re: sixpackgut]
#1055204
08/18/11 05:24 PM
08/18/11 05:24 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My car is a original 340 car and I left the 340 T-bars in it.No limiters and it hooks pretty good.
