BB A Body Torsion bar #1055188
08/17/11 10:56 PM
08/17/11 10:56 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
A body guys, what torsion bar you running with a BB?
and can someone tell me the diameters of the A body bars? think i have /6 and maybe want to go SB
Re: BB A Body Torsion bar [Re: sixpackgut] #1055189
08/17/11 11:06 PM
08/17/11 11:06 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I just installed the /6 888-889 t bars!
Mopar Performance
Re: BB A Body Torsion bar [Re: moparniac] #1055190
08/17/11 11:19 PM
08/17/11 11:19 PM
Charleston
Charleston
Sledgie, what did you have? i'm goin to measure mine now
Re: BB A Body Torsion bar [Re: sixpackgut] #1055191
08/17/11 11:19 PM
08/17/11 11:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Id recommend the 318 bars with a BB. Thats what I use and love them. They are a little stiff for me because Im so light at 3000# but work great.
You can ID your bars by both the diameter and the identifying stamping numbers on them.
/6 bars are .83 diameter, stamped 889. on both sides.
318 bars are .85 diameter, stamped 890/891 R/L
340 bars are .87 diameter, stamped 892/893 R/L
Re: BB A Body Torsion bar [Re: Sport440] #1055192
08/17/11 11:39 PM
08/17/11 11:39 PM
Charleston
Charleston
mine are .830
i'm thinking i want to put small block bars in the car, limit front end to 2" of lift with a ladder susp. what do you think?
just took the car for its first ride and the front is dragging and i dont have much adjustment left
doesnt look to bad in this pic but it got worse
Re: BB A Body Torsion bar [Re: sixpackgut] #1055193
08/17/11 11:43 PM
08/17/11 11:43 PM
I have the stock 1971 6 non air cylinder bars in my Duster, I also ended up using the Koni SPA B body front shocks 1.41 60 ft. cork up so far It is street driven and rides fine this way
Re: BB A Body Torsion bar [Re: sixpackgut] #1055194
08/17/11 11:45 PM
08/17/11 11:45 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
What I've always heard, and think it's in the Mopar Chassis Manual, is if you are running a BB use SB T-bars. If running a SB use /6 T-bars. At least for drag racing.
Re: BB A Body Torsion bar [Re: Cab_Burge] #1055195
08/17/11 11:46 PM
08/17/11 11:46 PM
Charleston
Charleston
your 60 is not as good as my challenger though and i had SB bars in that car
Re: BB A Body Torsion bar [Re: aquamist60] #1055196
08/17/11 11:51 PM
08/17/11 11:51 PM
Charleston
Charleston
i had the /6 bars in the challenger and they worked good but it got faster when i changed to sb bars. less exciting though
Re: BB A Body Torsion bar [Re: sixpackgut] #1055197
08/17/11 11:52 PM
08/17/11 11:52 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
I've always used the 340 bars with my big block. I've never had a hooking or handling issue. I run a small tire and leaf springs with cal-tracs.
My car consistently goes 1.3 to 1.33 60fts.
It's a bigblock with a torque flight!!!
Re: BB A Body Torsion bar [Re: sixpackgut] #1055198
08/18/11 12:05 AM
08/18/11 12:05 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
mine are .830
If you want the limited travel like you do, then you will want the thicker 340 bars or thicker. How heavy are you?
@ 3000# my 318 SB bars are pretty stiff, but I still get 4" to 6" of front end lift or so. Your 2" lift max wont work IMO unless your some kind of chassis Guru.
Re: BB A Body Torsion bar [Re: mopar_to_ya] #1055199
08/18/11 12:08 AM
08/18/11 12:08 AM
Charleston
Charleston
you use the .870 bar? do you have limiters on your front or let'em hang?
Re: BB A Body Torsion bar [Re: Sport440] #1055200
08/18/11 12:14 AM
08/18/11 12:14 AM
Charleston
Charleston
mine are .830
no chassis guru, poor bob george had to answer 100 questions while i was attempting to weld this car together.
the more i watch fast cars go down the track the more i notice how even and uneventful their cars look while us slow guys are trying to put it on the bumper and act like mental patients.
i never had a ladder bar car so i dont know but i have only heard that "5 inches of travel" needed for the caltracs. i dont hear ladder bar guys saying that
Re: BB A Body Torsion bar [Re: sixpackgut] #1055201
08/18/11 01:00 AM
08/18/11 01:00 AM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
I have mine limited to 5" of travel. Mine will go almost 6" if left hang. But I really don't think you want that much with ladder bars. I may be wrong though, just what I've heard and seen. Hope this helps, and good luck with it!
Re: BB A Body Torsion bar [Re: sixpackgut] #1055202
08/18/11 02:28 AM
08/18/11 02:28 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run the .830 6-cyl. bars as the .810 drag bars kept sagging over time and these are going on 8 years and from a junkyard to boot.
Re: BB A Body Torsion bar [Re: sixpackgut] #1055203
08/18/11 03:37 AM
08/18/11 03:37 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
ray I had the 318 bars! what do you mean by "less exciting"
Ray just put big tall UCA bumpstops to limit travel some.
Mopar Performance
Re: BB A Body Torsion bar [Re: sixpackgut] #1055204
08/18/11 05:24 PM
08/18/11 05:24 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My car is a original 340 car and I left the 340 T-bars in it.No limiters and it hooks pretty good.
Nautilus Racing-
Re: BB A Body Torsion bar [Re: moparniac] #1055205
08/18/11 05:52 PM
08/18/11 05:52 PM
Charleston
Charleston
it didnt pull the front wheels as high with SB bars. do you want to sell your bars?
