Page 2 of 4 1 2 3 4
Re: engine assembly labor [Re: CompWedgeEngines] #1055033
08/18/11 04:07 PM
08/18/11 04:07 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
do like i did,i got banged in the u know what..and never went back to the guy!then found a humble dude that likes what he does for a living.and is very reasonable price wise.
Re: engine assembly labor [Re: fishy340] #1055034
08/18/11 06:16 PM
08/18/11 06:16 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I talked to a Bud down-the-street ... BBC guy .... who got -also.
He supplied all-the-parts to this famous HP rebuilder for his dually. He was charged for ring filing/fitting ... yet the rings he supplied were std 30 over.
Re: engine assembly labor [Re: fishy340] #1055035
08/18/11 06:26 PM
08/18/11 06:26 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Compwedge, you are RIGHT ON THE MONEY there.
For a performance engine build, 800 is not out of line. Checking clearances, maybe needing to get + or - .001 bearings, deburring parts, file fit and deburr rings, install cam bearings, wash the block and all the parts ( properly ), final assembly, it all adds up and when its done properly, it takes TIME.
Add setting up the top end, checking valve spring pressures and installed heights, valve to guide clearance, rocker arm alignment, etc. and it should easily be another $500.
I'm not an engine guy, but I am in a trade-type business. IF someone wants me to provide a service, and stand behind my work, sure no problem. Knock me down on my price, no thanks, go somewhere else.
BTW, if it's a Hemi, and you are having him assemble the short block only, I don't blame him for not degreeing the cam without having the Heads. He could set it at the cam grinder's spec with out having the heads, but to me that's only part of the degree job. With the heads on he can check piston to valve clearance at different degrees of crank rotation.
I wouldn't degree it without the heads either. If he did, you bolt the heads on, and fire it up only to have the valve hit the pistons, you'd come back with your head on fire accusing him of not doing his job. There's more to it than bolting stuff together. I know this, and I'm no expert. The real pros know.
I'm Gumby dammit!
Re: engine assembly labor [Re: Scotts71chall] #1055036
08/18/11 06:45 PM
08/18/11 06:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i also agree with compwedge. kick up the cash, don't be cheap. get it done right the first time. then have some fun with ur ride. stay safe, seeya.
Re: engine assembly labor [Re: Gumbydammit] #1055037
08/18/11 06:48 PM
08/18/11 06:48 PM
organ
maximum entropy Offline
organ
two different things. whoever does the top end is responsible for valve to piston clearance, and quench. i would never do a short block only. scary. gimme the whole job or go elsewhere.
Re: engine assembly labor [Re: maximum entropy] #1055038
08/18/11 07:00 PM
08/18/11 07:00 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
this is a shortblock topic!
Re: engine assembly labor [Re: fishy340] #1055039
08/18/11 07:17 PM
08/18/11 07:17 PM
Lost in Pooler, GA
Gumbydammit Offline
Gumbydammit  Offline
Lost in Pooler, GA
Well aware, just sayin.
I'm Gumby dammit!
Re: engine assembly labor [Re: Scotts71chall] #1055040
08/18/11 07:26 PM
08/18/11 07:26 PM
SW WI
cudacustoms1 Offline
SW WI
I was in the same position as you are with the same shop. I had them do the assembly on my BAE motor after having nothing but trouble with a different shop. They were very good to deal with. Since working with them I have talked to several different people I know that have used them and been happy with there work.
Re: engine assembly labor [Re: Scotts71chall] #1055041
08/18/11 09:30 PM
08/18/11 09:30 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
I dont know about the hemi but the engine builder I recently used charged 350. for long block asembly on a stroked small block
Re: engine assembly labor [Re: BLONDE BARRACUDA] #1055042
08/18/11 10:46 PM
08/18/11 10:46 PM
Delray beach, Florida
P
Performance Only Offline
P
350.00 for a stroker long block assembly? can you tell us the name of the shop please?
machine shop owner and engine builder
Re: engine assembly labor [Re: BLONDE BARRACUDA] #1055043
08/19/11 12:27 AM
08/19/11 12:27 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Something smells FISHY,and I now HATE the smell of fish!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: engine assembly labor [Re: hemi-itis] #1055044
08/19/11 01:18 AM
08/19/11 01:18 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
800 is fair. If another local shop is cheaper by a little, you could ask for the cam degree job to be thrown in.
I want my fair share
Re: engine assembly labor [Re: SomeCarGuy] #1055045
08/19/11 08:53 AM
08/19/11 08:53 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
800 is fair... you could ask for the cam degree job to be thrown in.
I agree...burn that bridge over $1-200. There are just some people you shouldn't do business with until their perception changes IMO. Let him take it to this other shop that is cheaper, I say. I like Todd's explanation/reasoning; How would you feel if daily, your boss adjusted (only downward) your wage based on your performance? As mentioned, I would also have the same shop do the entire assembly. But, if I were this original shop and happened across this post, I would not take the job. IMO the OP is unfamiliar with the work required. Also, you are unable to recognize accurate advice from respected/sucessful members. You even contradict yourself. I honestly hope you get this worked out and all parties win. But, again no self-respecting shop would do business with you in your current state of mind IMO.
Re: engine assembly labor [Re: BLONDE BARRACUDA] #1055046
08/19/11 11:24 AM
08/19/11 11:24 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
So spill the beans,Ms. Blonde Barracuda! Who did the long block for the "discounted" price of $350.00???
Re: engine assembly labor [Re: hemi-itis] #1055047
08/19/11 12:11 PM
08/19/11 12:11 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
I agree ....verrry FISHY-itis !
Re: engine assembly labor [Re: Scotts71chall] #1055048
08/19/11 01:41 PM
08/19/11 01:41 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
To me it sounds a bit on the high side, but not unreasonable. It takes a few days to correctly check and assemble, mock up, tear down, correct, clean, and re-assemble an engine. The question is what exactly are they checking, and correcting? How are they fitting the cam? How many times are they torque the studs and bolts? What will they correct for free, or charge extra for? What block prep are they doing? Are they installing the frost plugs and painting the block? What oiling system, how complicated a system (If they are installing it?) I think for the price they should degree the cam too?
I can see a long block costing more. It takes a bit of time to disasemble all the valves, check spring pressures, measure and correct spring install heights, mock up rocker gear, measure for pushrods, check and correct intake manifold fit, ect. I was thinking more like 16 hours at $50/hour = $800?
Re: engine assembly labor [Re: dOoC] #1055049
08/19/11 01:42 PM
08/19/11 01:42 PM
Visalia Ca
P
prostreet68 Offline
prostreet68  Offline
P
Visalia Ca
The shop that did the work on my motor said that its $1200 for him to do it.
Re: engine assembly labor [Re: 451Mopar] #1055050
08/19/11 05:41 PM
08/19/11 05:41 PM
P
P
is 50.00 bucks an hour the going rate where your located for a premier engine builder?
keep in mind that the OP is supplying the parts, so if they don't fit right, he has to pay for the correction also. those parts as delivered fitting properly is NOT the responsibility of the builder. it is his job to catch any problems and correct them though. after all, that's worth paying for, right???
Re: engine assembly labor [Re: prostreet68] #1055051
08/19/11 05:57 PM
08/19/11 05:57 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
The assembling cost is then appx 10% of the engine value, in parts. So it is no big deal. More important is to have it properly done, and documented, and a warranty in some way against assembly errors if something bad happens at a later stage. An unskilled assembler can easily destroy your high value parts, or set them up so they self-destruct. I think that will be all the difference. Saving 2-300$ is no deal if the 10-15k$ engine fails....
If it is a bread and butter sbc, then it is a completely different story. But, you got a Hemi....Keep it living, too many Hemis went down the drain. The worst engines I work on are Hemis that have had multiple repairs/overhauls.
My
Re: engine assembly labor [Re: dOoC] #1055052
08/19/11 08:58 PM
08/19/11 08:58 PM
hemi-itis Offline
hemi-itis  Offline
Page 2 of 4 1 2 3 4
