kickdown linkage on 68 dart ??? #1054873
08/17/11 06:22 PM
08/17/11 06:22 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
does anyone have a picture of the kickdown linkage for a 68 dart?i am puttin a 440 in it and i have numerous pieces and parts just dont know exactly how they go or even if i have the correct parts,i have the three piece linkage parts and pieces,thanks in advance
Re: kickdown linkage on 68 dart ??? [Re: bigblock4x4] #1054874
08/17/11 06:53 PM
08/17/11 06:53 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
If you have any type of service manual with a V8 in it that hasa 727 section .. that should give you the basics on how to put-it together.
Re: kickdown linkage on 68 dart ??? [Re: bigblock4x4] #1054875
08/17/11 06:59 PM
08/17/11 06:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The tech archives has pics of several different setups:
http://www.moparts.org/Tech/Archive/auto/35.html
Re: kickdown linkage on 68 dart ??? [Re: John_Kunkel] #1054876
08/17/11 08:08 PM
08/17/11 08:08 PM
pana illinois
pana illinois
is there a better picture of what the actual bracket on the intake looks like,i have got about three different ones and i don't think i have the correct one,the little bracket the kick-down hooks too that i have wants too hit the bulkhead connectors when i run it thru it's coarse,thanks
Re: kickdown linkage on 68 dart ??? [Re: bigblock4x4] #1054877
08/17/11 11:01 PM
08/17/11 11:01 PM
TX
68 Dart GTS Offline
68 Dart GTS  Offline
TX
if you are not interested in the original linkage and pains, lokar has a throttle kick down cable set up that has worked great on my 440 68 dart and is very simple to install with great throttle response.
good luck, send me your e-mail and i can send you pics of my set up if you like.
Re: kickdown linkage on 68 dart ??? [Re: dOOc] #1054878
08/18/11 12:35 AM
08/18/11 12:35 AM
pana illinois
pana illinois
i have an old 68 chiltons of my dads would it b in there do ya reckon?
Re: kickdown linkage on 68 dart ??? [Re: bigblock4x4] #1054879
08/18/11 12:51 AM
08/18/11 12:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Doubt it . Chilton manuals were a waste of a good tree.
Make it easy on yourself and run a Bouchilon cable setup, then you won't have to worry about it hitting the bulkhead connector or the fact that it's not setup correctly for a mopar.
Re: kickdown linkage on 68 dart ??? [Re: JohnRR] #1054880
08/18/11 08:18 AM
08/18/11 08:18 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
here is a pic for a small block out of a chilton manual ( imagine that). like already stated if your not worried about original then just go cable. to me its a lot cleaner and easier. i always use the lokar set up and have never had any issues with it. always worked flawlessly on all my big block or small block abodies.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
