victor big block heads vs indy EZ #1054871
08/17/11 06:08 PM
08/17/11 06:08 PM
bigfork mn
dragram440 Offline OP
bigfork mn
I was just wondering what head was capable of more power. I know the indy takes the standard rockers where the victors take offset. I havent done much research on the ez's
67' charger 499 RB 10.57 at 127
Re: victor big block heads vs indy EZ [Re: dragram440] #1054872
08/17/11 06:17 PM
08/17/11 06:17 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Some of those EZ heads take the larger offset rocker arm... They are basically a 440-1 with the standard exh port location..
I would imagine all these heads come from the same couple of molds...
Just like the SR and -1... Same casted head, just machined diff.
I would give the nod in the power department to the Victor head, although I have zero experience with these heads... yet...
Pick the power level you want then pick the top end...
Either of these should have no trouble making 750-800 hp without getting exotic.
On the same motor the Victor setup will make more power however...
It not a good comparison IMO...
Better compared would be the 44-1 or SR as these heads have both raised exh and intake ports, just like the Victors.
