4 corner idle VS 2corner circuit adjustment #1054865
08/17/11 04:32 PM
08/17/11 04:32 PM
B.C. Canada
hankcrank Offline OP
B.C. Canada
I have read many posts on the idle mixture screw adjustments on Holley carbs.I read 1-1/2 turns out for a starting point on all carbs. I have read 3/4 turn out for a starting point.
I have been told from cab. experts 1-1/2 turns out on a 2 corner carb. and 3/4 turn out on 4 corner idle circuits.
Does anyone know for sure what is the right amount of turns for a starting point? 3/4 to 1-1/2 is quite a difference.
Re: 4 corner idle VS 2corner circuit adjustment [Re: hankcrank] #1054866
08/17/11 05:39 PM
08/17/11 05:39 PM
Andrews,In. U.S.of A.
67_Satellite Offline
A starting point is just that. You're going to adjust it up and down anyway. If it starts with the screws 3/4 turns out, and runs long enough to make your adjustments,it will be o.k.
Re: 4 corner idle VS 2corner circuit adjustment [Re: hankcrank] #1054867
08/17/11 06:03 PM
08/17/11 06:03 PM
I would tune it to make you happy I like and use from 1/4 turn to 1 full turn on most of my motors with big cams idling at or under 1000 RPM, I do open the idle bleeds up to help lean the idle circuit down also I like to see from 14.5 to 15.8 AFR on my wide ban, that does make it cold blooded to start when cold but so what Lean is mean Now if I can get the part throttle near 14.0 or above I'll be good Another thing to use on tuning the idle circiut is to stand at the rear or side of the car where the exhaust exits and smell it, if it is rich you will smell it, if it is not rich it won't stink as bad, even with good smelling race gas One other last thing, if you can start the car cold and it idles right away your probally on the rich side on the idle circiut
Re: 4 corner idle VS 2corner circuit adjustment [Re: hankcrank] #1054868
08/17/11 06:25 PM
08/17/11 06:25 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
No one can say what your engine will like.. Every engine is diff. Cam size plays a roll, way to many variables. If your interested in learning how to properly tune your engine, get a base line and start making changes... Only one change at a time though...
Re: 4 corner idle VS 2corner circuit adjustment [Re: Bob_Coomer] #1054869
08/17/11 09:14 PM
08/17/11 09:14 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I AGREE 100% YOU ARE RIGHT BOB.
Re: 4 corner idle VS 2corner circuit adjustment [Re: hankcrank] #1054870
08/18/11 06:26 PM
08/18/11 06:26 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Given that the timing is set correctly, the air bleeds are properly sized and throttle blade position at idle is covering the correct amount of the idle transfer slots, I run them 1/2 to 3/4 of a turn out from lean mis-fire.
Screw them out just until the idle will no longer increase, then screw them back in until it starts to lean mis-fire (idle decreases) then back out 1/2 to 3/4 of a turn. Go around until they are all consistently 1/2 to 3/4 of a turn out from lean mis-fire. it may take several times to balance/stabilize them.
