Re: ALUMINUM HEAD POROSITY
[Re: maximum entropy]
#1054821
08/17/11 06:19 PM
08/17/11 06:19 PM
Posts: 1,019 Finland
mafo
Finland
Goodson sell a very good product called SEAL ALL block and head sealer, works for me
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: dOoC]
#1054822
08/17/11 06:56 PM
08/17/11 06:56 PM
Posts: 8,880 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
There is a 3 step stop-leak process that I helped a friend with some years back. It stopped a head-gasket leak ...so it should "cure" a little porosity.
But its a secret so he's not going to tell us what it is !!!
[Re: Stanton]
#1054823
08/17/11 07:02 PM
08/17/11 07:02 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Hey WISE GUY ...if I could have remembered the brand I would have mentioned it. .... ...
I think he got it at NAPA ...
#1054826
08/17/11 08:11 PM
08/17/11 08:11 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
We had a B/B that leaked coolant into the oil from what was thought to come from the head. it was found that it leaked only the engine got hot and pressure in the radiator rose to 14lb. No way would it stop everything was tried with no luck until the coolant was replaced with EVANS which does not boil until 370 degrees. so it never got that hot and only a zero lb cap on the radiator. last chance repair is still working
home of the Sox and Martin Hemi Duster
[Re: POS Dakota]
#1054832
08/18/11 06:05 AM
08/18/11 06:05 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Maybe this is it...
I finally found it!
There is a Smokey Yunick reference to sodium silicate (waterglass) in that forum. IMHO this is the only fix that will last because it will not be affected by engine heat after.
Kevin
#1054833
08/18/11 11:02 AM
08/18/11 11:02 AM
Posts: 572 Shelbyville, TN USA
40ford
mopar addict
mopar addict
Shelbyville, TN USA
We have dealt with cylinder head (and block) porosity for years---starting with W2s that had been ported too far. And W5s, early Arringtons, W7s, and even the aluminum sprint blocks. We found the best repair was to carry the problem part(s) to a full line cylinder head repair shop. There, they use a waterglass solution, under pressure, heated to stop the leak. Sometimes, the treatment only takes one hour, sometimes the treatment requires eight hours---but it has always gotten repaired. You probably will need to make your own block off plates for any heads(18 or 20 heads).
And, you get the advantage of better heat retention in aluminum heads=====better horsepower.
[Re: 40ford]
#1054834
08/18/11 12:40 PM
08/18/11 12:40 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Good point regarding the better heat retention. I never thought of that.
