ALUMINUM HEAD POROSITY #1054819
08/17/11 03:12 PM
08/17/11 03:12 PM
organ
maximum entropy Offline OP
organ
a racing buddy of mine has a set of bulldog heads on his duster that have had issues with porosity. specifically, one of the exhaust ports is seeping coolant. he's had it welded, and it's seeping again, in the bowl area. his welder said it's not repairable this time. do any of you guys have any experience with this problem? any "miracle cures"?
Re: ALUMINUM HEAD POROSITY [Re: maximum entropy] #1054820
08/17/11 03:19 PM
08/17/11 03:19 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
There is a 3 step stop-leak process that I helped a friend with some years back. It stopped a head-gasket leak ...so it should "cure" a little porosity.
Re: ALUMINUM HEAD POROSITY [Re: maximum entropy] #1054821
08/17/11 06:19 PM
08/17/11 06:19 PM
Finland
mafo Offline
mafo  Offline
Finland
Goodson sell a very good product called SEAL ALL block and head sealer, works for me
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: ALUMINUM HEAD POROSITY [Re: dOc !] #1054822
08/17/11 06:56 PM
08/17/11 06:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
But its a secret so he's not going to tell us what it is !!!
Re: ALUMINUM HEAD POROSITY [Re: Stanton] #1054823
08/17/11 07:02 PM
08/17/11 07:02 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Hey WISE GUY ...if I could have remembered the brand I would have mentioned it. .... ...
I think he got it at NAPA ...
Re: ALUMINUM HEAD POROSITY [Re: Stanton] #1054824
08/17/11 07:18 PM
08/17/11 07:18 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I saw a thread on this subject on speedtalk forum a while bck and there was some good useful info on this very subject. Might be worth checking it out. I remember several concotions being mentioned. One thaat's poured into the head then I think baked. Forgot what it was called though...
One of the brands was called "kreme" I think.
Re: ALUMINUM HEAD POROSITY [Re: dOc !] #1054825
08/17/11 07:22 PM
08/17/11 07:22 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Sometimes it is to thin in the area to weld,we usually lightly peen the area with a round head punch and rub some high temp Lab Metal or similar into the porosity holes.Them we put a sealer in the cooling system,usually Dyke or other sealer.
Re: ALUMINUM HEAD POROSITY [Re: maximum entropy] #1054826
08/17/11 08:11 PM
08/17/11 08:11 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
We had a B/B that leaked coolant into the oil from what was thought to come from the head. it was found that it leaked only the engine got hot and pressure in the radiator rose to 14lb. No way would it stop everything was tried with no luck until the coolant was replaced with EVANS which does not boil until 370 degrees. so it never got that hot and only a zero lb cap on the radiator. last chance repair is still working
home of the
Sox and Martin Hemi Duster
Re: ALUMINUM HEAD POROSITY [Re: POS Dakota] #1054827
08/17/11 09:32 PM
08/17/11 09:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That was a very good post by head porter Darrin Morgan. When I read this post I went to Speedtalk to try and find it but didn't have any luck locating it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ALUMINUM HEAD POROSITY [Re: pittsburghracer] #1054828
08/17/11 10:53 PM
08/17/11 10:53 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Try some Waterglass http://en.wikipedia.org/wiki/Sodium_silicate
Old school cure that is cheap and effective.
Kevin
Re: ALUMINUM HEAD POROSITY [Re: pittsburghracer] #1054829
08/17/11 10:59 PM
08/17/11 10:59 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Maybe this is it...
I finally found it!
Re: ALUMINUM HEAD POROSITY [Re: camdog440] #1054830
08/17/11 11:18 PM
08/17/11 11:18 PM
PA.
"Little"John
"Little"John
PA.
Maybe this is it...
I finally found it!
Good job. I must be getting blind in my old age. I looking for that post for about 30 minutes earlier today and couldn't find it. I saved it in my favorites for future reference.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: ALUMINUM HEAD POROSITY [Re: camdog440] #1054831
08/18/11 12:47 AM
08/18/11 12:47 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Maybe this is it...
I finally found it!
Re: ALUMINUM HEAD POROSITY [Re: POS Dakota] #1054832
08/18/11 06:05 AM
08/18/11 06:05 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Maybe this is it...
I finally found it!
There is a Smokey Yunick reference to sodium silicate (waterglass) in that forum. IMHO this is the only fix that will last because it will not be affected by engine heat after.
Kevin
Re: ALUMINUM HEAD POROSITY [Re: maximum entropy] #1054833
08/18/11 11:02 AM
08/18/11 11:02 AM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
We have dealt with cylinder head (and block) porosity for years---starting with W2s that had been ported too far. And W5s, early Arringtons, W7s, and even the aluminum sprint blocks. We found the best repair was to carry the problem part(s) to a full line cylinder head repair shop. There, they use a waterglass solution, under pressure, heated to stop the leak. Sometimes, the treatment only takes one hour, sometimes the treatment requires eight hours---but it has always gotten repaired. You probably will need to make your own block off plates for any heads(18 or 20 heads).
And, you get the advantage of better heat retention in aluminum heads=====better horsepower.
Re: ALUMINUM HEAD POROSITY [Re: 40ford] #1054834
08/18/11 12:40 PM
08/18/11 12:40 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Good point regarding the better heat retention. I never thought of that.
Re: ALUMINUM HEAD POROSITY [Re: POS Dakota] #1054835
08/18/11 07:33 PM
08/18/11 07:33 PM
organ
organ
a lot of good info here. thanks all!
