The best hemi 4 bbl intake for hood clearance? #1054622
08/17/11 11:26 AM
08/17/11 11:26 AM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
I have a built 426 hemi in a 1968 dodge charger street car. Im using a 850 demon carb and want to use a mopar 4 bbl intake only. I DONT WANT TO CUT THE HOOD and want to use an air cleaner. Can someone tell me what intake they used (like P4876188?) Thanks
Re: The best hemi 4 bbl intake for hood clearance? [Re: ts70rt] #1054623
08/17/11 11:27 AM
08/17/11 11:27 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I have a stock MP dual plane, let you have it for 125 plus the ride!
Re: The best hemi 4 bbl intake for hood clearance? [Re: astjp2] #1054624
08/17/11 01:03 PM
08/17/11 01:03 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
A carb on the stock MP dual plane will NOT fit under the hood, I couldn't close my stock hood on my Charger without the rear hinges raised a bunch until I installed a throttle body.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: The best hemi 4 bbl intake for hood clearance? [Re: ts70rt] #1054625
08/18/11 12:26 AM
08/18/11 12:26 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I've got an MP dual plane on my 528 Hemi topped off with an 850 demon carb. I'm running the factory chrome dome air filter (66-68 style) with a single 4bbl base.
This setup fits just fine in my 68 Coronet under the factory power bulge hood. I think the bulge provides a little extra space which you might not have with a Charger hood.
Re: The best hemi 4 bbl intake for hood clearance? [Re: Paul_B] #1054626
08/18/11 01:21 AM
08/18/11 01:21 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I am using the MP single 4bl with my roadrunner.
750 Holley 3310.
Had to use a shorter air filter, but it fits with a stock hood.
