Kenne bell and a 5.7 #1054456
08/16/11 11:34 PM
08/16/11 11:34 PM
Canada
Cape Offline OP
Cape  Offline OP
Canada
Can anyone tell me what's the max psi you can run in a 09 5.7 Hemi with a kenne bell supercharged or just any supercharger. Thanks
Re: Kenne bell and a 5.7 [Re: Cape] #1054457
08/17/11 01:11 AM
08/17/11 01:11 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Depends on how bottom end is built and compression. I would say on a stock block without any changes no more then 8 psi.
Mike
1969 Dodge Dart Swinger
Re: Kenne bell and a 5.7 [Re: MikeyT] #1054458
08/18/11 02:25 PM
08/18/11 02:25 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
and 8 psi will make you some power!
