Wheel Alignment on a 68 dart #1054343
08/16/11 10:26 PM
08/16/11 10:26 PM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
can some one tell me what front Wheel Alignment spec you are useing on your a bodys? need specs fot a 1968 dodge dart with a stock front end. it a drag car only that goes 150 mph and weights 3200 pounds. thanks Ed
Re: Wheel Alignment on a 68 dart [Re: HEMI472] #1054344
08/16/11 11:50 PM
08/16/11 11:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Their all the same(pretty much) for a race car and
stock suspension ... as much caster as you can get,
0 camber, 0 to 1/16" toe in... this is done with the
body up 1" to simulate at speeds... I would advise
doing a toe curve check to see that it doesnt go toe
out... thats bad
Re: Wheel Alignment on a 68 dart [Re: MR_P_BODY] #1054345
08/16/11 11:51 PM
08/16/11 11:51 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
like Mike said
home of the
Sox and Martin Hemi Duster
Re: Wheel Alignment on a 68 dart [Re: MR_P_BODY] #1054346
08/17/11 01:30 AM
08/17/11 01:30 AM
PA
moparacer Online content
moparacer  Online Content
PA
out... thats bad
That is the way my 68 is set up and I have been 145.
Only suspension mod up front is a set of solid strut rods.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Wheel Alignment on a 68 dart [Re: moparacer] #1054347
08/17/11 01:39 AM
08/17/11 01:39 AM
MD
HEMI472 Offline OP
HEMI472  Offline OP
MD
THANKS FOR YOU HELP
