440 Breakin Question #1054176
08/16/11 07:24 PM
08/16/11 07:24 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
I've got nearly everything ready to startup, but recall that I may have used moly lube on the lifter walls. Have read where they should be clean and/or with a little WD40, so they can rotate freely during breakin. Should I pull the intake (ugh) and correct?
Re: 440 Breakin Question [Re: 70runner] #1054177
08/16/11 07:56 PM
08/16/11 07:56 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
If its worth anything, I finished building a 318 this weekend and for the lifters I just smeared a bit of oil in the lifter bore and dropped them in there. 300 miles so far, so good.
Re: 440 Breakin Question [Re: 70runner] #1054178
08/16/11 08:03 PM
08/16/11 08:03 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
If theres a chance the lifters are gooed up on the sides with Moly, YES, the lifters need to rotate freely from moment one.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 440 Breakin Question [Re: 70runner] #1054179
08/16/11 08:06 PM
08/16/11 08:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i thought Moly Lube WAS for break in???
Re: 440 Breakin Question [Re: HemiRick] #1054180
08/16/11 08:08 PM
08/16/11 08:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Break-in lube on the lifter contact face and motor oil in the bores. If you pick the lifters up off the cam lobe they should drop back down by themselves easily.
Re: 440 Breakin Question [Re: Neil] #1054181
08/16/11 09:05 PM
08/16/11 09:05 PM
70runner Offline OP
70runner  Offline OP
Yea, I know I did the drop "thunk" test on the lifters - had to clearance one bore which was a little snug...just can't remember if I gooed them up with lube before I did final assembly
Re: 440 Breakin Question [Re: 70runner] #1054182
08/16/11 09:17 PM
08/16/11 09:17 PM
Run it! Just open a door so you don't get "sleepy" from the exhaust
Re: 440 Breakin Question [Re: 70runner] #1054183
08/16/11 09:27 PM
08/16/11 09:27 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Can't you pull a valve cover off and stick a flashlight down one of the pushrod holes to see if there is any assembly lube squishing out around the lifter?
The lifter to lifter bore clearance is tight so even if there is assembly lube inbetween the two it's not going to be a huge amount and what little there is will be wiped off after a few cycles. Can you turn the engine over by hand and watch the lifter to see if it turns?
Re: 440 Breakin Question [Re: Neil] #1054184
08/16/11 09:43 PM
08/16/11 09:43 PM
70runner Offline OP
70runner  Offline OP
Yea, the valve covers are just laying there. I'll give the flashlight idea a shot. Thx for your suggestions. I REALLY don't want to remove that intake man, redo the valley pan and gaskets...
Re: 440 Breakin Question [Re: 70runner] #1054185
08/16/11 09:59 PM
08/16/11 09:59 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You can pull distrib and run a priming tool for a while to wash some of that moly out of there, BUT it will also wash the moly off of cam lobes.
Re: 440 Breakin Question [Re: buildanother] #1054186
08/17/11 01:16 AM
08/17/11 01:16 AM
70runner Offline OP
70runner  Offline OP
Yea, I think I'm pretty much stuck with pulling the intake/valley pan. Lesson learned I guess. I kept good notes on everything I did but for whatever reason didn't write down anything about the lifters...
Good news is I can re-moly the cam while I'm in there since I turned the crank a few turns while attaching the flexplate/TC.
