Re: Carb numbers
[Re: shakerjoe]
#1053983
08/16/11 01:27 PM
08/16/11 01:27 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
not to hijack the op, but oe carbs didn't have the 7 digit part # on the throats - correct ? Those would be replacement carbs - right ? I passed on a set years ago for a set with just the holley list # and dates - paid more for the second set than the first - thanks.
That is my understanding
Re: Carb numbers
[Re: FC7 cuda]
#1053985
08/16/11 05:20 PM
08/16/11 05:20 PM
Morty426
Sacramento CA
Any pictures of them?
I can get you pictures tonight if Scott doesn't drop back in here with them
Re: Carb numbers
[Re: shakerjoe]
#1053986
08/16/11 06:10 PM
08/16/11 06:10 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Roger, the carbs I think should be 4382 front, 4375 center, 4383 rear, and the intake on the car was a 3412046 - might be correct for the build date of it - BO5 - Joe
Is that the alum intake number ? A 70 usually had a cast iron intake.
Re: Carb numbers
[Re: shakerjoe]
#1053988
08/17/11 12:02 AM
08/17/11 12:02 AM
Morty426
Sacramento CA
didn't some early build 70's get the left over alum. intakes left over from the A12 program ? Build date on fender tag is BO5 - the door sticker is 11/69 -
Correct. The later the car the more likely the cast iron intake. The transition is in the Oct / Nov time frame. The cast Part # is 2946216.
Here is a photo of an original carb list number and date.
