CAL TRACS ON A BODIES #1053849
08/16/11 01:46 AM
08/16/11 01:46 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
LOOKING FOR PICS OF THE FRONT END OF CAL TRACS. TRYING TO SEE HOW MANY DIFFERENT WAYS EVERYONE IS ADJUSTING THEM.
Re: CAL TRACS ON A BODIES [Re: rickb67] #1053850
08/16/11 02:04 PM
08/16/11 02:04 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I have mine adjusted with an 1/8" gap under the tranfer bolt. My car has been scaled and goes straight. Don't have a pic of the front. Jim
Re: CAL TRACS ON A BODIES [Re: rt66jim] #1053851
08/16/11 02:53 PM
08/16/11 02:53 PM
Guitar Jones Offline
I had mine in the upper hole with just touching the left side spring and 1 turn of preload on the right spring with me in it. Sorry no pics of it though.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: CAL TRACS ON A BODIES [Re: Guitar Jones] #1053852
08/16/11 03:11 PM
08/16/11 03:11 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Ours just touches the springs on both sides with a 1/4 turn of preload on pass side. Straight as a string...
Re: CAL TRACS ON A BODIES [Re: cudadoug] #1053853
08/16/11 08:11 PM
08/16/11 08:11 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
This will sound stupid. But normal for me do you mean the upper hole in the the triangle shaped plates.
Re: CAL TRACS ON A BODIES [Re: rickb67] #1053854
08/17/11 07:32 PM
08/17/11 07:32 PM
NC
O
onefastindy Offline
onefastindy  Offline
O
NC
I've got mine on the top holes with about 3/16 air gap and shocks set on #3. My car 1.29 60 ft. on 125 shot.
