Page 3 of 3 1 2 3
Re: Full boogie Indy-SR heads for street/strip... [Re: markz528] #10532
05/05/04 09:47 PM
05/05/04 09:47 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
These are my SR's:
Opening Intake Exhaust
.200 158.7 120.1
.300 220.8 170.5
.400 271.3 203.2
.500 301.4 225.7
.600 326.0 247.6
.700 345.4 262.3
.800 354.9 269.0
First run spinning the tires and heading for the wall went 9.88 @ 136.54 mph in my 3525 Coronet. 12.5:1 compression with Comp Cams .650 lift flat tappet cam.
After reading what you wrote, I hope I Screwed up my combo enough to slow me down a little, I havent been down the 1/4 in 24yrs. My last pass was 14.48.
My current motor is a 511, full race ported SR's, 13.75cr with a .705 roller in a 65 Belvedere
I think I need to buy a box of Depends
71 GTX 4sp Dana GY9 HD Road King
Re: Full boogie Indy-SR heads for street/strip... [Re: AZ-Nick] #10533
05/05/04 09:53 PM
05/05/04 09:53 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
....YES SIIIIRRRRRRRRRRRRRRRRRRRRRRRRRR! I hope to GOD I'm standing in the pits when you return after your 1st full "to the wood" pass! I am dying to see the look on your face Nick
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Full boogie Indy-SR heads for street/strip... [Re: gregsdart] #10534
05/05/04 10:09 PM
05/05/04 10:09 PM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
Un, a move right to 440-1s will get you these flow numbers or better if you get the SR without the dogleg, or the 440-1s,either with a 2.25 intake. I have heard that the SRs may have a little more short side to work with, so they might even outdo the 440-1s if ordered without the pushrod problem.
My 440-1s;
int .100 74 - 76 ex 50 - 58
int .200 149 - 154 ex 104 - 117
int .300 210 - 223 ex 145 - 170
int .400 263 - 278 ex 180 - 209
int .500 301 - 328 ex 210 - 245
int .600 311 - 363 ex 237 - 270
int .700 313 - 368 ex 250 - 287
int .800 306 - 378 ex 257 - 301
First set of numbers is before with 2.19 intake, second after porting ,2.25 intake.
The biggest shortblock you can build is the way to go, and in my estimation that is a set of wiseco 4.375 pistons with 1.300 compression hieght, with a 4.25 crank from ohio or eagle. 6.635 rods,all in a 400 block, and don't forget to figure in the 9cc for valve reliefs (yep, 9cc) for a big roller of up to 284@ .050 if you ever choose to go that big.
This motor should be capable of running 10.00 to high 9s if you build it with a roller, even staying under 7000 rpm and having a somewhat streetable converter in it. The power i estimate is about 725 hp, probably at about 6600 to 6800 rpm.
I was kind of wondering the same thing, especially after talking with 572Charger on the way back from the PGD's. I think the -1's is the way I am going to go this winter.
Re: Full boogie Indy-SR heads for street/strip... [Re: EvilB1Dart] #10535
05/05/04 10:13 PM
05/05/04 10:13 PM
USA
FY1CUDA Offline
FY1CUDA  Offline
USA
Wes, Got video?? Too funny! I'd like to see that myself! Buckle Up!
Your first driveway test will serve as a good reminder for a couple of test passes before the all outs! Good Luck and have fun! 14.4's?? Your gonna love it!
Re: Full boogie Indy-SR heads for street/strip... [Re: FY1CUDA] #10536
05/05/04 11:02 PM
05/05/04 11:02 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
65,
I want a full video of that pass!
WIZE
In Car:
Re: Full boogie Indy-SR heads for street/strip... [Re: Streetwize] #10537
05/06/04 12:27 PM
05/06/04 12:27 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
If I can strap MRMOPAR to the roof of the car with his video camera, I will have a great movie for sure. If not, I hope to have him or someone else get a video of it from the stageing lanes.
The video is not what is needed, I might bring along a tape recorder to record my screams and yells that may come from me inside the car.
Re: Full boogie Indy-SR heads for street/strip... [Re: AZ-Nick] #10538
05/06/04 10:11 PM
05/06/04 10:11 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Hey Gary, why not just go the whole hog and buy a set of B1 originals!!!
AL...
Alan Jones
Re: Full boogie Indy-SR heads for street/strip... [Re: AZ-Nick] #10539
05/07/04 01:33 PM
05/07/04 01:33 PM
Anonymous OP
Anonymous OP
These are my SR's:
.200 158.7 120.1
.300 220.8 170.5
.400 271.3 203.2
.500 301.4 225.7
.600 326.0 247.6
.700 345.4 262.3
.800 354.9 269.0
65 thanks for the good laugh. Just the OMG what have I done to myself attitude that you wrote it in cracked me up. You might want to double bag yourself for that first run.
Re: Full boogie Indy-SR heads for street/strip... #10540
05/07/04 09:27 PM
05/07/04 09:27 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
Maybe NASA can loan me one of their space suits, at 300lbs, the situation could get ugly real fast.
Re: Full boogie Indy-SR heads for street/strip... [Re: AZ-Nick] #10541
05/07/04 10:18 PM
05/07/04 10:18 PM
USA
FY1CUDA Offline
FY1CUDA  Offline
USA
Seriously, I can't wait until you,Wes, Steff, B1Cuda, Gary etc. are done!
Good luck to you all!
Re: Full boogie Indy-SR heads for street/strip... [Re: Prostock] #10542
05/07/04 10:19 PM
05/07/04 10:19 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Tom, if I remember right, last year at that cruise you said 11s were fast enough You can never go too fast, I knew it was just a matter of time!
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Full boogie Indy-SR heads for street/strip... [Re: Silver70] #10543
05/08/04 12:13 AM
05/08/04 12:13 AM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
I was also still married at the time! :lol: This time I won't have to hear "are you done spending money"..."is that all you need to get"....
Leave it to Joe to bust my balz.....
Re: Full boogie Indy-SR heads for street/strip... [Re: Prostock] #10544
05/08/04 12:38 AM
05/08/04 12:38 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I bet seeing those cars in Memphis was also a factor Of course just seeing Jims car all the time can't help! I know myself, after seeing Jims car on the dyno, I had to build the best I could right now... anything else would just be slow, still will be compared to his car, but I'm trying! Got to start somewhere.
I'm sure I'll be joining ya with some -1s down the road... but I'll admit to it now
Re: Full boogie Indy-SR heads for street/strip... [Re: FY1CUDA] #10545
05/08/04 08:41 AM
05/08/04 08:41 AM
gregsdart Online content
gregsdart  Online Content
After following this post and others, it would seem that you are deffinately one of us "adrenallin junkies", so that would say plan for "more power!!!!!" in the future. We never get enough!! The SRs will make good power, and get you there, but will hit a wall(power wise) at a certain point. Will it be enough? Maybe for a year or so? Then what? Are you the type that will want to go to the next level in the future, and then look back and say "I wished i had,,,,,,,"
For me, i am kicking myself for having sold that 4.5 billet crank and having stayed with the 440-1s!!!!!!!!!!!
With the $$ i spent, i could be within $3000 of a 1050 hp 572!
If i ever bail on the racing, this motor (the 528)will turn into something bigger,(588?) with less compression and the same heads, for a streetable 700 to 750 hp!
Re: Full boogie Indy-SR heads for street/strip... [Re: AZ-Nick] #10546
05/09/04 11:14 AM
05/09/04 11:14 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
65 after the 3rd run you will be able to tell us the trap RPMs, Oil presure, Fule presure, Watter temp, and Voltage,in the traps, and how mutch you had him by at the stripe.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Page 3 of 3 1 2 3
