I AM RUNNING A 1.65 SPRING. I CALLED T AND D, THEY TOLD ME TO "CLEARANCE" OR GRIND THE ROCKER IN THE AREA OF THE RETAINER. doES NOT TAKE MUCH AND YOU ONLY NEED ABOUT .035 (THICKNESS OF A PAPER CLIP)
aFTER GRINDING I POLISHED THEM WITH FINER GRADES OF SANDPAPER TO GET RID OF ANY DEEP SCRATCHES THAT COULD START A CRACK OR WEAK SPOT. AFTER RUNNING THEM LIKE THAT YOU MAY SEE SOME "WITNESS" MARKS FORM THE RETAINER SLIGHT CONTACT, JUST CLEARANCE A LIL MORE IN THOSE SPOTS. OBVIOUSLY MAKE SURE YOU WASH THE ROCKERS GOOD BEFORE REINSTALLING THEM,
