SUMMIT SB balancers
#1053354
08/15/11 11:15 AM
08/15/11 11:15 AM
Posts: 611 Muncie
Racebuddy
Muncie
Just installed my new Summit small block balancer. It went on very tight. After installing I noticed that the engraved timing marks are to the outside of the balancer and not on the inside closests to the timing mark on the front cover. this seams very weird. I have one other summit balancer and a Rattler and they have their marks close to the front cover. The way this balancer is marked it will make it difficult to use the timing light and set timing. Anyone else see this problem with their Summit Balancers??
Re: SUMMIT SB balancers
[Re: Racebuddy]
#1053357
08/16/11 01:16 PM
08/16/11 01:16 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
thanks thats a good tip. just frustrated that new parts come with problems
Then welcome to a world of XXXX because it doesnt get any better! LOL
[Re: Racebuddy]
#1053358
08/17/11 01:10 PM
08/17/11 01:10 PM
Posts: 7,506 Az
Crizila
Az
How I solved that problem - and made an adjustable pointer at the same time.
Fastest 300
[Re: Crizila]
#1053359
08/17/11 01:24 PM
08/17/11 01:24 PM
Posts: 7,506 Az
Crizila
Az
---- and while you got the H20 pump off, you might as well make this mod.
Fastest 300
[Re: Crizila]
#1053360
08/17/11 02:01 PM
08/17/11 02:01 PM
POS Dakota
detroit, mi
Awesome! lol A poor man's flowkooler mod. How much did it help you?
[Re: Crizila]
#1053362
08/17/11 02:39 PM
08/17/11 02:39 PM
POS Dakota
detroit, mi
No clue, but I can run in 100 degree outside temps with 15 minutes between rounds and the motor stays under 200. Mod cost next to nothin, so why not?
I totally agree with you...and on a lot of your previous points on other stuff. How's the DUI holding up BTW?
