SUMMIT SB balancers #1053354
08/15/11 11:15 AM
08/15/11 11:15 AM
Muncie
Racebuddy Offline OP
Muncie
Just installed my new Summit small block balancer.
It went on very tight. After installing I noticed that the engraved timing marks are to the outside of the balancer and not on the inside closests to the timing mark on the front cover.
this seams very weird. I have one other summit balancer and a Rattler and they have their marks close to the front cover.
The way this balancer is marked it will make it difficult to use the timing light and set timing.
Anyone else see this problem with their Summit Balancers??
Re: SUMMIT SB balancers [Re: Racebuddy] #1053355
08/15/11 11:43 AM
08/15/11 11:43 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I took a straight edge ruler and extended my marks over with a white paint stick. By the way check the timing marks as mine were off by 3 degrees. I also painted my damper black on both sides of my timing marks ( TDC and 36 degrees ) because the timing marks were hard to see on the shiny surface with the timing light.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SUMMIT SB balancers [Re: pittsburghracer] #1053356
08/15/11 02:42 PM
08/15/11 02:42 PM
Muncie
Muncie
thanks thats a good tip. just frustrated that new parts come with problems
Re: SUMMIT SB balancers [Re: Racebuddy] #1053357
08/16/11 01:16 PM
08/16/11 01:16 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Then welcome to a world of XXXX because it doesnt get any better! LOL
Re: SUMMIT SB balancers [Re: Racebuddy] #1053358
08/17/11 01:10 PM
08/17/11 01:10 PM
Az
Crizila Offline
Crizila  Offline
Az
How I solved that problem - and made an adjustable pointer at the same time.
Fastest 300
Re: SUMMIT SB balancers [Re: Crizila] #1053359
08/17/11 01:24 PM
08/17/11 01:24 PM
Az
Crizila Offline
Crizila  Offline
Az
---- and while you got the H20 pump off, you might as well make this mod.
Fastest 300
Re: SUMMIT SB balancers [Re: Crizila] #1053360
08/17/11 02:01 PM
08/17/11 02:01 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Awesome! lol A poor man's flowkooler mod.
How much did it help you?
Re: SUMMIT SB balancers [Re: POS Dakota] #1053361
08/17/11 02:36 PM
08/17/11 02:36 PM
Az
Crizila Offline
Crizila  Offline
Az
No clue, but I can run in 100 degree outside temps with 15 minutes between rounds and the motor stays under 200. Mod cost next to nothin, so why not?
Fastest 300
Re: SUMMIT SB balancers [Re: Crizila] #1053362
08/17/11 02:39 PM
08/17/11 02:39 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I totally agree with you...and on a lot of your previous points on other stuff. How's the DUI holding up BTW?
Re: SUMMIT SB balancers [Re: POS Dakota] #1053363
08/17/11 02:51 PM
08/17/11 02:51 PM
Az
Crizila Offline
Crizila  Offline
Az
Awesome. In 3 years worth of beatings the only thing I have done is roll in a fresh cap and rotor. You do need a charging system that will feed it 13.8 to 14.2 consistantly. I have run gaps as wide as .055" with no problems. Normally run .040" though.
Fastest 300
