Stock engine block freeze plugs? #1053309
08/15/11 09:54 AM
08/15/11 09:54 AM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
When Mopar put their engines together did they use brass or steel freeze plugs?
Re: Stock engine block freeze plugs? [Re: 74RR] #1053310
08/15/11 09:57 AM
08/15/11 09:57 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just steel unless they went to brass as of late.
Re: Stock engine block freeze plugs? [Re: buildanother] #1053311
08/15/11 10:36 AM
08/15/11 10:36 AM
74RR Offline OP
74RR  Offline OP
Thanks,so they might have gone to brass in the later models?
Re: Stock engine block freeze plugs? [Re: 74RR] #1053312
08/15/11 12:21 PM
08/15/11 12:21 PM
chicagoland,usa
chicagoland,usa
That I don't know, but some later GM stuff has brass.
Re: Stock engine block freeze plugs? [Re: buildanother] #1053313
08/16/11 12:47 PM
08/16/11 12:47 PM
dogdays Offline
dogdays  Offline
Steel in '87, once passed on a car with one rusted out behind the flexplate. My free '87 318 is also steel, they're coming out.
R.
Re: Stock engine block freeze plugs? [Re: 74RR] #1053314
08/16/11 01:03 PM
08/16/11 01:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
AFAIK,
No brass plugs in a mopar of any year as factory installed
