jag fan clutch #1052884
08/14/11 05:15 PM
08/14/11 05:15 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..about 3/4" shorter than standard mopar unit.
. do they perform ok ?
Re: jag fan clutch [Re: can.al] #1052885
08/14/11 09:16 PM
08/14/11 09:16 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
They work fine but don't look as a stock Mopar, also you have to machine out the center hole in the pulley..
I prefer to use the TRW FC28, Mopar OE replacement only 2.75" high. Check out the internet and swap meets...
Just my $0.02..
Re: jag fan clutch [Re: Sinitro] #1052886
08/14/11 09:34 PM
08/14/11 09:34 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..machining?
..i thought you had to use the supplied sleeve to centre the unit on the water pump?
Re: jag fan clutch [Re: can.al] #1052887
08/15/11 08:57 AM
08/15/11 08:57 AM
Greer, SC
TooMany62s Online content
TooMany62s  Online Content
Greer, SC
I bought the Jag fan clutch that's supposed to work. The fan bolt pattern wasn't even close. I don't know if I got the wrong one or if you need to buy a fan to go with it. I think I still have it someplace. If I can find it I'll post a picture. maybe someone has a picture of the correct one?
Re: jag fan clutch [Re: can.al] #1052888
08/15/11 12:11 PM
08/15/11 12:11 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The Jaguar fan clutch, Hayden part number 2765, is 2.67" tall and SHOULD come with a bushing for the center pin. I installed it on my 1971 383 which fit just like it should. Bolted right up. No problems.
No machining required.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: jag fan clutch [Re: Junky] #1052889
08/15/11 12:47 PM
08/15/11 12:47 PM
Norway
General 68 Offline
General 68  Offline
Norway
Just put one in myself.
Re: jag fan clutch [Re: General 68] #1052890
08/15/11 01:55 PM
08/15/11 01:55 PM
Me three.
I just bought one about a month ago and it came with the bushing. It bolted up perfectly to the Mopar fan that I had.
Here's a quick pic of it installed:
Re: jag fan clutch #1052891
08/15/11 02:08 PM
08/15/11 02:08 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I've had two so far on my 383 stocker they work but my first one started to leak after about 5K and both of them do not lock up tight even when hot, i think they were designed for a smaller possibly plastic fan
Re: jag fan clutch [Re: ademon] #1052892
08/15/11 02:35 PM
08/15/11 02:35 PM
Greer, SC
Greer, SC
I know the part number on the box was 2765 but the part was nothing like the one in the picture above. I guess I'll try again.
Re: jag fan clutch #1052893
08/15/11 04:01 PM
08/15/11 04:01 PM
SINY
SanityLost Offline
SanityLost  Offline
SINY
Me three.
Whats the measurement from the core to the fan clutch, in the picture it looks real close.
Anyone else with pics and measurements PLEASE post them
Re: jag fan clutch [Re: SanityLost] #1052894
08/15/11 04:31 PM
08/15/11 04:31 PM
Me three.
It would NOT fit with the stock radiator location. I had the local radiator shop move the side brackets back about 1/2".
Before it would slip in but was up against the radiator.
Now it has about 1/2" clearance although getting a good pic is difficult.
Re: jag fan clutch [Re: can.al] #1052895
08/15/11 06:38 PM
08/15/11 06:38 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Why are we going through all this trouble to use a Jag fan?
What do I not know?
Re: jag fan clutch [Re: Commando1] #1052896
08/15/11 06:47 PM
08/15/11 06:47 PM
What do I not know?
I wanted a clutch fan but the normal shaft length is way too long.
The "Jag" Hayden clutch looks almost identical to the Mopar clutch other than the length of the shaft.
edit
Oh yeah, to clarify the fan is not included. We're just talking about the clutch element here.
Early B's are really tight when it comes to radiator/fan clearance when compared with later B/E bodies.
FYI, this is a 440 in the stock location with the original style K-frame in a '63 Dodge 330 with factory BB engine mounts. Nothing aftermarket.
After messing with it, I can see why guys use the later B-body K-frame to move the engine and trans back! It causes firewall/tranmission bolt access issues and you have to cobble up a rear transmission mount but in the end I think a later K would be worth it!
Re: jag fan clutch #1052897
08/15/11 08:26 PM
08/15/11 08:26 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I had to do the same thing.
Re: jag fan clutch [Re: Junky] #1052898
08/15/11 09:35 PM
08/15/11 09:35 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I used the jag clutch in my 67 Barracuda When I went to a three core aluminum Champion radiator. Much thicker rad then my stock copper/brass two core. I had no choice but to use the jag clutch. Otherwise my fan would not fit, would hit the rad. It bolted right up, came with a center bushing as mentioned above. Super tight install though. Not much room for fat fingers.... Lol.
Re: jag fan clutch [Re: Suregrip391] #1052899
08/15/11 09:38 PM
08/15/11 09:38 PM
The other thing you might want to do is make sure you put the belt over the fan blades BEFORE you bolt the radiator in.
Re: jag fan clutch #1052900
08/16/11 09:49 AM
08/16/11 09:49 AM
Commando1 Offline
Commando1  Offline
What do I not know?
So waht y'all saying is the Jag clutch is thinner?
It brings the fan further back from the radiator and closer to the block?
Re: jag fan clutch [Re: Commando1] #1052901
08/16/11 10:08 AM
08/16/11 10:08 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Exactly. The correct clutch has not been available for years and if you find an NOS one it is $$$$.
Re: jag fan clutch [Re: Commando1] #1052902
08/16/11 11:38 AM
08/16/11 11:38 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
What do I not know?
Not thinner. It has a shorter shaft. From where it bolts to the water pump to the face of the clutch is 2.67". Put another way, place it on a table facing up, it is 2.67" tall.
Re: jag fan clutch [Re: Junky] #1052903
08/18/11 12:30 PM
08/18/11 12:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
So am i the only one that thinks the jag fans are "weak" meaning they don't spin the fan quite fast enough when hot?
