Re: New cam & 1 bad lifter ?
[Re: racincuda]
#1052263
08/13/11 10:12 PM
08/13/11 10:12 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
Most will run it,not me. As stated the cam lobe will not use the edge but when I see a casting issue(I have been casting for over 20 years)I'd be worried about the problems below what you can see. :twocents
[Re: goldmember]
#1052268
08/14/11 12:21 AM
08/14/11 12:21 AM
Posts: 650 Kansas
racincuda
Kansas
thought I would contact mfgr monday and giv em a chance at suppling a new lifter before I blast them on a public forum. With damage that close to the face im more than a little concerned. But will that one lobe handle a second breakin cycle Any new lifter is prob better than this one
[Re: racincuda]
#1052271
08/14/11 04:34 AM
08/14/11 04:34 AM
Posts: 30 Australia
Charger VJ RB
Australia
I could not use that lifter no way, with a successful break in that lobe will be in good condition to handle a new lifter. Lifters get replaced all the time for many different reasons.
RB XE274H Q-850
Re: New cam & 1 bad lifter ? UPDATED
[Re: racincuda]
#1052274
08/16/11 11:07 AM
08/16/11 11:07 AM
RapidRobert
Cant beat that . I would suggest makeing sure the lifters have enough clearance in the bores. Mockup & raise each lifter off the lobe w your finger/let go & it should fall back onto it's respective lobe w a resounding "thunk" on brake kleened and lightly WD40 lubed bores/lifters. 25 yrs ago that cam co that moved to Florida (forget who) paid me several hundred $$ to go back into an eng from their bad merchandise after I sent them an itemized/detailed bill. that's unheard of
