Steering Components #1052135
08/13/11 03:29 PM
08/13/11 03:29 PM
Spokane Washington
Dodgeem Offline OP
Dodgeem  Offline OP
Spokane Washington
Does anyone know where I can find an idler arm for a 1970 Duster that doesn't wear out 3 months after I install it? NAPA, Auto Zone, and Pep Boys is not recommended. Any recommendations for upgrade kits is appreciated as well.
Re: Steering Components [Re: Dodgeem] #1052136
08/13/11 05:00 PM
08/13/11 05:00 PM
MD
Moparlang Offline
Moparlang  Offline
MD
It's very odd that an idler arm would wear out that fast regardless where it came from. Are you running headers or is the vehicle lower than stock specs.?
The "mailman's son" Bad mailman!!
Re: Steering Components [Re: Moparlang] #1052137
08/13/11 08:11 PM
08/13/11 08:11 PM
Spokane Washington
Dodgeem Offline OP
Dodgeem  Offline OP
Spokane Washington
I am running headers, the vehicle is at stock height according to the service manual. The mechanics at the local shops can't figure it out and the parts stores say it's the geometry of the suspension. I've only had one idler arm from NAPA that has lasted longer than a year. I even re-lube it as they suggested. Every three months when I drive it regularly. It's very frustrating. I'm considering going to PST or Just Suspension to get a whole new front end kit. It just costs an arm and a leg and i'm trying to avoid it. Thanks for the reply!
Re: Steering Components [Re: Dodgeem] #1052138
08/13/11 08:28 PM
08/13/11 08:28 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Get a Moog brand. They are the best that there is...if those are wearing out when properly greased....you have another problem. Advance should have them...my car is low and has headers...I haven't had issues like this.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Steering Components [Re: goldduster318] #1052139
08/13/11 10:51 PM
08/13/11 10:51 PM
IN
ahy Offline
ahy  Offline
IN
Agree Moog is good.
Are there any witness marks from the idler hitting the headers or anything else?
Re: Steering Components [Re: ahy] #1052140
08/14/11 09:07 AM
08/14/11 09:07 AM
USA
540DUSTER Offline
540DUSTER  Offline
USA
do you have any vibrations you can feel in the steering wheel?
Re: Steering Components [Re: 540DUSTER] #1052141
08/14/11 12:01 PM
08/14/11 12:01 PM
Spokane Washington
Dodgeem Offline OP
Dodgeem  Offline OP
Spokane Washington
No whitness marks. No vibes. Only play when it starts to go out. I'll try the Moog component. Thanks!
