World block main studs #1052020
08/13/11 11:37 AM
08/13/11 11:37 AM
WI.
Scotts71chall Offline OP
WI.
Whats the best place to get only the replacement main studs, (the nuts are ARP) for a iron World Hemi block?
Was there a member selling them for a good $$
Re: World block main studs [Re: Scotts71chall] #1052021
08/13/11 01:09 PM
08/13/11 01:09 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Just ordered two sets from JEGS. They were $75.00 plus all their garbage add ons. Best price that I found. Everywhere else was over $100.00. Part number I purchased was ARP 145-5603
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: World block main studs [Re: Scotts71chall] #1052022
08/13/11 01:47 PM
08/13/11 01:47 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: World block main studs [Re: 451Guy] #1052023
08/13/11 03:03 PM
08/13/11 03:03 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I got a 572 block and i changed all of my studs because they did not put ARP studs in and my block was new and i got my studs from ARP i payed $120.00 for them because JEGS was out when i needed them and i got the same part #145-5603 as you did .
Re: World block main studs [Re: steeldust] #1052024
08/13/11 03:53 PM
08/13/11 03:53 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
"you can replace the main studs with ARP #AR4.620-1LB X 8 and #AR4.400-1LB X 2. I did a google search and vendors have them for aprox. $5.50 each. "
Mopar Performance
Re: World block main studs [Re: moparniac] #1052025
08/13/11 05:15 PM
08/13/11 05:15 PM
WI.
WI.
Sledge
I saw that in another thread also, could you say what vendor or post a link?
Re: World block main studs [Re: Scotts71chall] #1052026
08/13/11 06:16 PM
08/13/11 06:16 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I have them in stock here.
RIP Monte Smith
