Too much tire? #1051878
08/13/11 09:05 AM
08/13/11 09:05 AM
gregsdart Offline OP
I guess I already new the answer, just didn't realize it? My car went fastest with a 15.1 x 33.6 x 15 stiff sidewall tire, but is still slower than 440JIMs car. My best is a 1.259, his best is somewhere in the 1.22s. I run 8.80s Jims car is in the mid/low nines.
I kept thinking that maybe it was some roll out, better converter, what ever. But then while playing with the Dragstrip 2000 program, it showed 60 ft gains the smaller I went with the rear tires. Not small gains, but a full .02x going down to a 31.25 x 12.5 x 15. Go figure. OK chassis experts, your experiences?
P.S. I am sort of looking for that majic combo, consistancy plus speed!
Re: Too much tire? [Re: gregsdart] #1051879
08/13/11 09:34 AM
08/13/11 09:34 AM
tboomer Online work
tboomer  Online Work
Greg...I always like the way you think. What do you have for gears and tranny? Wouldn't that come into play?
Re: Too much tire? [Re: tboomer] #1051880
08/13/11 09:49 AM
08/13/11 09:49 AM
Thanks, Ted. I run a 4.56 gear, torqueflite, 6500 stall. I have some latitude on trap rpm, so a drop from a 106 roll out to 101 to 102 would be workable, as long as the tires have some growth to them. I do run a trans brake, so I assume I need at least a medium stiff sidewall tire. Goodyears smallest listed Supergas type tire comes in at 5 lbs lighter per tire, 102 roll out 14 inch tread.
Re: Too much tire? [Re: gregsdart] #1051881
08/13/11 09:51 AM
08/13/11 09:51 AM
tboomer Online work
tboomer  Online Work
I can't remember what Jim runs,but I think he has 4:10s in the back..
Re: Too much tire? [Re: tboomer] #1051882
08/13/11 10:06 AM
08/13/11 10:06 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Shorter+lighter tire should = less rolling resistance which should = quicker. How much quicker? but the physics should be on your side.
Didn't Fred end up going faster with a smaller tire? I've forgot the details but I thought he was going to run in some tire limited class and he was surprised to still hook and go quicker.
Kevin
Re: Too much tire? [Re: Twostick] #1051883
08/13/11 12:50 PM
08/13/11 12:50 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I went a little faster when I switched from a 14.5 x 32W to a normal 14 x 32. Also Jim races in Maryland where the DA is often well below sea level, I'd love to run my car at that track..... could be my 8 second pass right there.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Too much tire? [Re: nhramark] #1051884
08/13/11 01:42 PM
08/13/11 01:42 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Look into a MT radial slick.....they are fast tires.
Re: Too much tire? [Re: gregsdart] #1051885
08/13/11 02:28 PM
08/13/11 02:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your talking 60' times.... JMO but your tire width
doesnt come into play(assuming traction isnt a problem)
in the 60', yes the diameter does because it changes
the rpm... I know you like to have a HIGH stall which
to me is past the power point of your engine and I
think thats where you loose your 60' but you cover
it up on top end with the revs.... down track the
tire width becomes a player with drag and wind resistance...
again JMO
Re: Too much tire? [Re: MR_P_BODY] #1051886
08/13/11 05:56 PM
08/13/11 05:56 PM
I guess stall could affect it some. But the car did go faster overall going from 5500 to 6500. When I ran the 8.77 with a 1.27 60 ft I was running radial M/T drag slicks, 14x33 at 34 lbs each. The tires I have now are 39.2 each. Best I have been able to post with the big tires is 1.259 with an 8.86 ET.
Re: Too much tire? [Re: gregsdart] #1051887
08/13/11 07:30 PM
08/13/11 07:30 PM
Trumbull,CT.
Trumbull,CT.
What was the reason you got away from the radial slick???
Re: Too much tire? [Re: jim sciortino] #1051888
08/13/11 11:19 PM
08/13/11 11:19 PM
They were down right evil in the handling department. They would put the car into what has become known as "radial rock" or swinging side to side during the run, building as you go sometimes. It was so bad I lifted half the runs on those tires, and a couple of guys asked why I didn't lift on a couple of others. When someone can see it from the starting line, its really bad!
Re: Too much tire? [Re: gregsdart] #1051889
08/14/11 10:17 AM
08/14/11 10:17 AM
tboomer Online work
tboomer  Online Work
This is interesting...So here is a for you,Greg!
Re: Too much tire? [Re: gregsdart] #1051890
08/14/11 10:38 AM
08/14/11 10:38 AM
NC
440Jim Offline
440Jim  Offline
NC
Greg,
Although my best times are as shown in my sig (sea level, 55 Deg), in the normal summer temps (85F) and mid life tires (100 passes), 1.275 is more typical.
Phoenix 12.2 x 31.25 W, 31.8" tall, published weight 33 lbs, plus inner tube ~9 lbs
The sig was 4.30 gears, this year 4.10, but I don't see any significant difference (just like when I put 4.56 in it when the 4.30 broke). In the beginning of this year, with 4.10 gears and 193 passes on the old slicks it did 1.241 at 57 Deg air temp (30.02"Hg good air) with a 9.18 ET.
And 26" front tires for rollout comparison.
I have thought about trying a M/T 10.5W tire, but I doubt I would get the 200+ passes on a set at 3250 lbs like I do now with the larger tire. So cost would go way up, even if it works.
Re: Too much tire? [Re: gregsdart] #1051891
08/14/11 12:16 PM
08/14/11 12:16 PM
Trumbull,CT.
Trumbull,CT.
Wow....that ain't good.
Re: Too much tire? [Re: gregsdart] #1051892
08/19/11 09:27 PM
08/19/11 09:27 PM
NC
440Jim Offline
440Jim  Offline
NC
So, Greg
What decision or plan have you decided?
The 14x32 slick is a great all around tire, IMO.
Since I run the "W" version, it is wider/heavier than the non-W and works great on a 14" wide rim. Phoenix 12.2 x 31.25 W, 13.6" wide tread, 31.8" tall, published weight 33 lbs, plus inner tube ~9 lbs.
And even at 11 psi, my 3250 lb car puts a good wrinkle in that tire on launch.
Re: Too much tire? [Re: 440Jim] #1051893
08/28/11 12:59 PM
08/28/11 12:59 PM
farmingdale ny 11735
blracing Offline
blracing  Offline
to go fast you would run the smallest tire you can still hook with.(less rolling mass)for consistancy (bracket racing)you would run the biggest tire you can fit!give up a little ET for win lights!!!
